In V4.2, where in the settings editor do I change the size of the point approach/retract direction arrow?
point vector direction arrow size
I don't have v4.2 but did you check in the setup? I know you can change the deviation graphic arrow size under the "arrow multiplier".I used to be high on life but I built up a tolerance.
Originally posted by Underspec View PostI don't have v4.2 but did you check in the setup? I know you can change the deviation graphic arrow size under the "arrow multiplier".
Looked and found nothing labeled as such in the options or settings editor.Xcel & MicroVal Pfx & Global 37mr4 thru 2012mr1sp3
Contura Calypso 5.4
by LukeXYZWe can't figure out how to increase the Arrow size showing the direction vector that shows in your cad window when you f9 a feature, we have tried all...
01-17-2020, 06:31 AM -
by jonasi go into edit and graphics display and display symbols to change the arrow size of the vectors when i use auto features, but it doesn't matter what arrow...
11-03-2009, 06:07 PM -
by inspector212Where in the Demon can you adjust the length of the surface vector arrow, the angle vector arrow, the start angle arrow(circles) and the end angle arrow(circles)?...
04-12-2011, 10:02 AM -
by littlejoeI'm trying to change my arrow size. This is the point arrow shown on cad durring execution. I'm running version 4.1. I've done the open gl thing in...
10-13-2006, 09:50 PM -
by Long PhamDoes any one know how to increase the size of the BLUE ARROW when using auto features with CAD? When I click on the model some time the arrow is so small...
07-11-2007, 11:57 AM -
