I know this is probably a easy fix but I am a rookie at programing so please excuse my ignorance. I want to add a tip angle (T1A90B0) to an existing probe file in a new program that I am writing. This Probe File already contains tip angles at forty-five degree increments (T1A90B +/-45 to +/- 180). I can add the tip angle that I want but when I go to calibrate it the probe fouls (Interupted Movement) on the forth point of contact on the calibration sphere. The calibration is set to take thirteen points per tip and all of the other tip angles run through calibration with no problems. I did notice that when going to the fourth hit in calibration of this tip the CMM speads up. How can I get this tip angle (T1A90B0) to calibrate? Thanks.
