good afternoon, i have a question about Jog Mode( mach/part/probe) How important is this. i havent seen anything in the posts about it so i am curious about it. i have parts that use datums that are cylinders with +/-.005" tp callouts and +/-.001" diameters that i think that this might affect the programs.
Jog Mode
Jog modes on the joystick box (that doesn't even sound right) are for manual moves only. If you're running DCC, don't worry about it. If you are in manual mode, it does help to hit normal to the surface if you're on an angle, or the probe is angled.sigpic Life is not a journey to the grave with the intention of arriving safely, but rather a skid in broadside, totally worn, proclaiming WOW What a ride!
Originally posted by Kevin Watts View Posti will try it, but ive never used any auto features except for auto circle to check location of a threaded hole. Ill give it a try though
Open the Auto Feature you want, say a Surface Point. Set the pre-Hits to 3, then click on the part where you want to take the point. Look at bottum left of window and it will tell you what to do, works great with Circle too.sigpicSummer Time. Gotta Love it!
Originally posted by craiger_ny View Post99 times out of 100 I edit right in the edit window.
Also, sometimes when I edit in the edit window and then go back and edit the feature a second time (because I goofed) it doesn't prompt to updated measured values or hits.
Also #2 - in F9 if you don't change the number of hits it won't regenerate them.
now im lost. pcdmis3.5mr1
no cad just part. do i need cad for this cause i dont have cad drawings. i have the autofeature open and am lost as to what to do next. im trying it out on a 1" ring gage to test the features. i have a cylinder on id for alignment. what next, i need to try to create a cylinder on the id
Originally posted by Kevin Watts View Postok i got it now, ive just created my first auto cylindersigpicSummer Time. Gotta Love it!
by giantslayerWhen I program a lot of the time I do it with my Jog mode as part. Today I was trying to make a quick program to check an angle, had my jog mode as part...
02-24-2015, 11:08 AM -
by 12345BS Global 12.22.10
V3.7 MR2
Jog Box:
I hold down enable,
move joy stick in X, Y or Z
I let go of joy stick
probe...-
11-11-2008, 05:54 PM -
by Shueythe renishaw ph10m controller says its in "auto" mode and I can't change angles manually. How do I put it into "manual" mode?
11-04-2009, 03:14 PM -
by BOBN1Here Is My Problem My I Had An Unfortanate Accident And The Jog Box Hit The Floor. Luckily Everything Is Still Working Except For I Lost My Probe Beeps....
04-10-2007, 01:46 AM -
by dragonbladeAll the appropraite lights are on and everything is operational as it is supposed to be on the JOG BOX> HOWEVER, randomly, when I press the ENABLE...
06-09-2010, 09:00 AM -
