i have a profile of a line callout on a print it is to the centre of a groove using cad data i measured points on the inside an then the outside of the groove i created midpoints between the measured features,i took the midpoints an created a line i can see a deviation of approx 1.2 mils in the y value between the Theo an the Actt line but when i do the profile an get a very small error .07 i tried different workplanes what am i missing thx
profile of a line
Jesse, please fill in all user info per http://www.pcdmisforum.com/showthrea...highlight=user.
Thanks, Jan.***************************
Originally posted by jessejames View Posti am using profile an form i am using 3.7r3 i will fill the user info next time i am really stuck for time
I believe the question to you JesseJames was: Are you using Profile Form AND Location or Form ONLY?
There's a BIG DIFFERENCE...sigpic
PCDMIS 2012
Windows Office XP
OK, I want to get this straight.
You picked points from a model and measured them so you KNOW the nominals are correct.
You constructed mid points from two sets of points (presumably 'diametrally opposed' or as close as you can get). Since the original points taken from the model are defined correctly then you KNOW the midpoint set is defined correctly.
You construct a line from all the midpoints you just constructed.
You profile this line and graphically is shows up as 1.2mm but reports as 0.7mm?
OK, when you construct this line which plane do you construct it in?Bill Jarrells
by markyIf I measure a 2D circle and want to know its profile (not form or roundness), would I dimension it as "profile of a line" and is this how I...
05-16-2011, 09:31 AM -
by W0QNXI have a surface with first a profile of form to ABC within .010 then below that box is a profile of line .005 / 2.000. Is this some kind of within .005...
05-14-2013, 02:25 PM -
by gppcdmisLet's say you're results on profile points come out to lowest -.007 and highest +.016.
The profile callout is .020 and profile of line is .010....-
05-10-2012, 10:47 AM -
by John RigginsI have a rather long part that has a Line Profile specification.
Imagine a banana (keep yer mind outa the gutter graiger).
This banana is...-
11-11-2006, 07:43 PM -
by Chinadaddy02
Good morning and happy holidays
Been running on ver. 3.5 for a while, now working at a place that is using 4.3 Rel for...-
12-21-2010, 09:12 AM -
