I have a program (4.1) that was created about two weeks ago. I didn't finish it but it was working fine up to the point where I stopped. I started adding onto it yesterday and now when I do True position (legacy) it give me the option to MMC all the datums. The problem is that datum A is a plane and B is a line. The previous True Position dimensions are still working correctly but if I true position them again they also do the same thing. Doesn't matter where I place the dimension in the program. I reconstructed the alignment using Datum A, B, and C and the dimension work fine. I am concerned that something strange is going on though. Is there a way I can copy the syntax from the program into a new program?
Program corrupted
Originally posted by calbritton View PostI have a program (4.1) that was created about two weeks ago. I didn't finish it but it was working fine up to the point where I stopped. I started adding onto it yesterday and now when I do True position (legacy) it give me the option to MMC all the datums. The problem is that datum A is a plane and B is a line. The previous True Position dimensions are still working correctly but if I true position them again they also do the same thing. Doesn't matter where I place the dimension in the program. I reconstructed the alignment using Datum A, B, and C and the dimension work fine. I am concerned that something strange is going on though. Is there a way I can copy the syntax from the program into a new program?sigpicRegards,
Donald Henger
B&S Micro Excel Pfx
3.5mr2 & 3.7mr3
PHH10MQ, TP20 & TP2
Country Rocks,But Bluegrass RULES!!!
Use Legacy Dimensions
I suspect your problem is that you have enabled the newer GD&T tolerancing. Go to Insert / Dimension/ and select the last item in the menu list, captioned "Use Legacy Dimensions".
other than that, you can always do a Save/As to have a copy of your program, or you can also cut and paste sections or entire programs from one to another.
by Paul SarrachFirst time I have had to use TP since June of last year. I can not believe it. So I figured out how to get the Datum scheme and all to make it work....
04-29-2008, 02:57 PM -
by turdbisketI believe I have created all of the features i need and have everything set up correctly. When i am in the True Position dialog box, I have datums created...
01-08-2007, 09:31 AM -
by MrCommentI have a program with suspect True position problems.
The attached pdf shows my report, from the default PCDMIS report template "textonly.rpt"...-
10-27-2006, 02:00 PM -
by rjdemyI am measuring a part that has multiple paste with pattern features. I forgot to put in a few FCF's, so i went back to add them and they are reading out...
08-03-2010, 08:21 PM -
by CarefullUsing PC-Dmis 2011 MR 1 ( Oct 12 2011), I was adding to a program off line , created several features with auto measure and auto label on, Then I moved...
01-22-2012, 01:08 PM -
