I have an air pressure fault or lube fault error. I have air supply to the CMM but I can't get the machine to start. What's next? Currently running MM4.
Air pressure fault
I cut the air supply and the air kinda back flushed some debris or moisture or something. I also emptied the cylinders that had moisture and debris in them. Apparently with the temperatures in the 100's there is a lot of moisture in our air supply, more than our air dryers can handle anyway.
You should present this issue to management ASAP. Moisture in your airbearings can foul things up. Make sure that there isn't any oil residue as this can be seriously detrimental to your machine. Either way you should persuade the powers that be to install a failsafe filter inline right before your machine.
We have an air dryer system that cleans/dries the air from the compressers and it is serviced periodically by an outside vender. I bleed the lines at least twice a week, but I still had water in the canisters at the final filters. Also I could see water droplets in the air line from the dryer to the CMM.
Originally posted by Brainedwashed View PostWe have an air dryer system that cleans/dries the air from the compressers and it is serviced periodically by an outside vender. I bleed the lines at least twice a week, but I still had water in the canisters at the final filters. Also I could see water droplets in the air line from the dryer to the CMM.
http://www.pcdmisforum.com/showthread.php?t=5743
Anyone know what the required air pressure for a Johansson Topaz 7 is supposed to be?
08-20-2014, 09:35 AM -
by biohazardI got a 2 bowl air pressure regulator and the second bowl is about half way full of oil. I'm guessing it is catching the oil from shop air and removing...
10-28-2013, 05:14 PM -
by hanssHi guys and hello, today my machine (B&S global) started making a pressured air sound while moving up in Z. It only happened for about 10 minutes,...
02-09-2011, 08:44 AM -
Hey guys,
I have two Globals, a Performance and a Status, on the same airline. Several times a night on second shift, the Status suffers...-
09-06-2012, 01:54 PM -
by BIGWIG7Hey fellas,
I'm having a hard time with the machine randomly losing air pressure.
I know for a fact that the CMM is being provided...-
01-15-2015, 11:03 AM -
