I usually end up checking this on the surface plate but I wonder there is a good way to check this on the CMM . I want to check the location of the intersection of the flange and the radius. The red line on the screen shot. Since the arc is only partial dia, I think I going to need to do this on the surface plate.
How can I do this?
I'm tried this many times but have had little success getting good or consistent readings. I usually use a video system if possible or the plate method as you mentioned....good lucksigpic.....Its called golf because all the other 4 letter words were taken
Originally posted by BANDY View PostI usually end up checking this on the surface plate but I wonder there is a good way to check this on the CMM . I want to check the location of the intersection of the flange and the radius. The red line on the screen shot. Since the arc is only partial dia, I think I going to need to do this on the surface plate.
but on a CMM, you could use very short line segments to find the measurement.
A side note: When you post, use a title that describes the problem. This helps the search function to work better and many times after you post the forum will list similar posts at the bottom that might answer your question... Posts with titles such BEER are of course, self-explanatory.
Originally posted by BANDY View PostI would like to see that smartscope. Where I can find one?
Originally posted by BANDY View PostLocated in Rancho Dominguez. Its Compton really. Almost at the end of the 91.
949-916-4400
Vision system is probably best thing. If you need to use CMM there is a method that works very well, better than short line segments. Depending on the size of the partial arc you may or may not be able to grab it but it is worth understanding at any rate,
If interested please PM me and I will send you a file.Bill Jarrells
by acncguyHello All -
A couple things:
I need to know once and for all if CMM's (in general) can accurately measure radii...-
01-31-2015, 05:49 PM -
by Perry FisherI'm checking several appliance parts that have very large radii to the tune of 360 inches. I only have 4° of radius available. I know this is no where...
06-01-2007, 01:07 PM -
by chainfeedI have a part here that is approx 4 x 4 square titanium plate with a 81.673 radius sphere. How would you guys go about checking the radius of the center...
03-03-2010, 08:22 AM -
by USMC81I have a print that calls out the locations of several cylinders along a 55.25" radius. When I dimensions these it gives me the straight line distance....
11-10-2011, 11:22 AM -
by 35DodgeI have a part that production would like to measure on the CMM. Please see sketch. The through bore and 30 degree angle form a sharp edge on the face...
11-17-2014, 11:48 PM -
