I have a need to export my dimensional information to excel. I have been able to do that but I notice that It will only let you choose a single alignment prior to exporting my data. Some of my dimensions are going be taken from different alignments. How can I overcome this problem with out having to output all my dimensions several times in each of the necessary alignments? I need to do this without the Advantage of Datapage.
Exporting Dimesnions Question
Cold Beer MMMmmmm........
Dell Precision T5400
Windows 7
B&S XCEL
WENZEL LH1512
PCDMIS 2011 MR1Tags: None
Originally posted by rerun_lives View PostI have a need to export my dimensional information to excel. I have been able to do that but I notice that It will only let you choose a single alignment prior to exporting my data. Some of my dimensions are going be taken from different alignments. How can I overcome this problem with out having to output all my dimensions several times in each of the necessary alignments?sigpic
Export whatever you want directly to a .TXT file using the Insert/File I/O Command/Writing Commands. Then pull the .TXT file into Excel.
http://www.wilcoxassoc.com/home.htm
go to the users area and scripts you have to register to download them but it is no big deal. You may also have to change the version of pcdmis you use in the excel file. Make a copy of it.sigpic
The way I do this is that I do my alignments and dimensions. Then I open the file and append whatever dimensions I need to the text file. Then I close the file. Then I go through my next alignments and do the same thing. This always gives me data in the latest alignment.
Sorry, but I think I still not get what the issue is.... Yes, muddy.... Hey, it's almost Miller time!
Still not working!!!
Originally posted by fmred79 View PostJust type this on the end of the program
And that's it
CS1 =SCRIPT/FILENAME= C:\EXCELSCRIPT.BAS
FUNCTION/LoadExcel,SHOW=YES,,
STARTSCRIPT/
ENDSCRIPT/
GOTO/C2
Was hoping this issue would be resolved by now. I am using 4.1 and I have downloaded the pcdmistoexcel_auto.zip file from the Wilcox website and followed the instructions of where to copy the files (C: drive) but when I go to try and type the above command line it will not let me do it. I have to use the "Insert\Script" command from the Insert dropdown menu and put a script in manually and then try to change it to match the line above. It refuses to let me type in the line "ENDSCRIPT/". I tried running it anyway without the line and it WILL NOT WORK, any other suggestions? I must be missing something - what is the "GOTO/C2" Line all about as well?sigpic
Windows 7
B&S XCEL
WENZEL LH1512
PCDMIS 2011 MR1
You NEVER type in the ENDSCRIPT/ line. PC-DMIS will put that there automatically after you finish the first time run of the script.
I have no idea what can cause your script problem. You will have to be more specific with what the message is that it returns when it poops out..
by adamclinardIs there a way to export data reports from dmis straight to an excel file?
11-21-2007, 01:53 PM -
by JVau425033I need to export to excel, but I dont want the whole report only the actual measured feature into a set cell. Does anyone know the string code?
01-06-2012, 10:17 AM -
by NMC_CMMI don't know if this is possible, or even worth doing, but I figured I'd ask anyway. We like to do 100% check on all our electrodes before they go to...
06-20-2008, 05:02 PM -
by thomasswayaRequesting the procedure to export data from PC-DMIS into a file that can be copied and pasted into Excel.
Thank you,
06-11-2010, 10:28 AM -
by Slug DawsonHello all,
We run Excel 2007 on our cmm computer. It has compatiability mode to allow the software to open up previous version of Excel spreadsheets...-
09-28-2010, 06:12 PM -
