Kind of embarrassing but I can find and good info on this, we usually do parts here that don't have this requirements. The print as it shows 2 coaxial holes, but don't have tolerance for the coaxiality. It has TP .001, as you can see in the attachment. Does it mean that holes should be coaxial within .001? or it just states the fact that this holes are on the same center?
How do you read this?
It shows the datums each being made up by the two coaxial holes. each datum is therefore a 3D feature used together as a datum for the profile. Something tells me that they would be in conflict with each other the way they are shown,
What 212 said, but if you run V4.2 (sorry...) you can evaluate this using XactMeasure GD&T.
That specific call you could not do in V4.0 (impossible) and V4.1 (had a major bug in it). I have exactly the same calls (except the coaxial hole note) and V4.2 finally allows me to analyze this as is.
by Gus101Hello,
I'm new to this and I came across a part (for the first time) that has datum feature A as a plane and B as 4 holes. Other features...-
Channel: PC-DMIS Portable
11-07-2016, 05:05 AM -
by MrXtopherOK, so I have a round part, a ring, that has 3 different sets of holes drilled into it. Lets call them the B, C, and E holes. They are all dimensioned...
08-24-2018, 08:55 AM -
Thanks to anyone that looks and helps. My problem is position of six holes. I have a triangle Sheet metal part that the bottom is Datum A and two holes...
08-15-2008, 08:48 AM -
by Mike_BI have a flange, football shaped. When assembled is secured with two bolts, on on each end. These 2 bolt holes are Datums B and C. The face of the flange,...
08-14-2013, 02:40 PM -
by WolfManI have a part with a bolt hole
patern holes 10 of them, they all need to be in one circular patern to datum A, which is a center point. the holes...-
08-15-2018, 01:03 PM -
