What's the best way to measure a Hexagon hole?
  • What's the best way to measure a Hexagon hole?
    Using vector points on the Cad model the actual hits are not in a normal pattern. Although the part pins out on the fixture. All round holes match up to their true position, and I know the hex hole is in true postion but when I vector the hex hole it does not center......am I missing something??
    If you want to measure a HEXAGON I would use PC-DMIS; perfect match.
    Get it? HEXAGON owns WILCOX? maker of PC-DMIS.
    No really, if you are using 4.0+ use the AUTO-POLYGON. Works like a charm.
      If you are using an older version, use a circle with 6 hits. You will need to use the REMEAS function and you wil lget a good locaiton. Size is a different matter.....
