Okay, I was changing Feature ID's name. Someone came in, hit space bar or enter, now I am getting invalid ID. I know what to do, but how many other options do I have. It will not let me put cursor anywhere nor let me type anything. God I am glad its friday though if really feels like a monday.
· If PC-DMIS locks up during manipulation of dimensioned items (invalid number entered), then with your right hand click “ok”. At the same time that you click”ok” use your left hand to hit CNTRL-S. This will save all of your work and then you can end the program with the task manager and re-open.
USE THE ARROW KEYS, Paula, they should make the cursor move where the problem is, then simply use SHIFT and ARROW to highligh and try that. BUT, once you get the cursor where the issue is with the arrow, you should also be able to back space and type to fix.
I'm having a problem with my cursor disappearing after I execute a feature. This is very annoying when trying to move your way step by step through a...
Today I was writing a program from the training manual and I went to put a move point in and it did not enter it in the edit window. I noticed that when...
so, I am working with an offline seat v2014. When I try to click on some of the drop down options then migrate the cursor to the iptions on the right...
Can I use auto circle in PRG file. I think I would have to put probe at the origin of hole, take move point, and then press F9 to enter theoretical co...
