I am measuring a .250 +.0005 -.0000 bore in the side of a chassis( looking from Y+). The CMM tells me the size is .2494 and I checked it with plugs and it measures .2502. The CMM also says the form is .0025. My alignment does not include the bore. I am actually measuring the size and location of the bore from the side of the chassis. Any help...
Help with measuring a .0005 bore
Well, this one will come back to the specs of your machine and equipment.
IF your machine specs are 0.0005" (which is pretty good), it is NOT good enough for that tolerance.
If you are using a TP2, you will not be able to check that tolerances on a hole.
AND, if you are looking for size and shape on something like that, you WILL need to eb aligned to it to ensure that you are getting proper comp for the probe hits.sigpic
Measure the bore as a cylinder, then simply LEVEL to the cylinder, measure a place on the face, intersect the cylinder and plane, set your XYZ origin to the intersection point. No rotation is needed since it is a round feature. I much prefer to set all 3 axis to a point not the cylinder alone since the axis of the length of the cylinder can then change with the measurements.sigpic
Originally posted by mattfurtaw View PostI measure the diameters of bore weekly and Hoedeman stated it correct. You must align to the bore in order to measure the diameter accuratly. Otherwords you get false information.
http://www.websophist.com/Pat_On_Back.jpgsigpicSummer Time. Gotta Love it!
Jeff, as stated by everyone else, use the cmm for location purposes. We have alot of small bores we have to measure, as we use Federal air gaging systems. You can check the size and roundness easily. However, if this is a one off deal, then you may just want to stick with gage pins, or bore mics. Air gaging systems get kind of costly and are not cost effective if you don't use them all the time.
Just my .01$
Note: If you have to check big bores ( like supervisors or bosses) a cattle prod works quite well.I don't feel tardy!sigpic
B&S "One" V4.2
Discovery D-12 V4.2
by Kevin Wattshey all
pcdmis 3.5 mr1
b&s global status
ph10t tp 20
hey i have a ridiculus tolerance on a bore 1.0223"...-
03-17-2008, 02:40 PM -
by bowhunter309I looking for a little help understanding what I'm doing wrong. I am trying to measure the diameter of a bore manually. Whenever I measure it, whether...
07-12-2019, 04:08 PM -
by jaymundayWe have a Final Inspection area that measures a 1.500 ±.001 ID with a Dyer Bore Gage. We had some parts show .0003 out of tol. I went to check the...
07-31-2019, 11:46 AM -
by operator1What is the best way to set up your alignment for a bored hole in a cylindrical part?
And when you level to the bore, what is that telling the...-
08-16-2007, 08:27 AM -
by TinyfxdsI need to measure a bore diameter and report if there is any taper in that bore. If I create two points at the quadrant of the bore, one at the top and...
12-31-2014, 08:48 AM -
