We are receiving an error message "primary point does not lie on secondary axis so tertiary is not allowed" when trying to use 3 datums to calculate TP using FCF. We have no problems when using two datums to calculate TP. The problem only occurs when using three.
True Position Problems with 4.2
Originally posted by GRS&S View PostWe are receiving an error message "primary point does not lie on secondary axis so tertiary is not allowed" when trying to use 3 datums to calculate TP using FCF. We have no problems when using two datums to calculate TP. The problem only occurs when using three.sigpic
by Bob PierceI have little to no experience using true position. The concept I need to grasp is this. Does the part alignment datums have to be the same as the datums...
04-19-2007, 01:43 PM -
by jessejamesOK we have a FCF that has a diameter callout an true position to Datums A B C
when generating the report an doing the tolerancing would you output...-
04-27-2007, 01:33 PM -
by TigerSharkHello again all
Just a question abot TP in Ver 4.2 MR1.
I have aligned a part by Itterative alignemnt and my datum-a...-
10-25-2007, 10:58 AM -
by cmmpro_mackOK.... Using 4.3MR1... Legacy Style TP Call Out... TP of a circle to A and B Datums... I have selected the feature and the datums in the dialog box.....
07-01-2011, 12:40 PM -
by NHopsonI am trying to measure a part with 4 holes aranged about a central bore that is datum B. There are basic dimensions to the 4 holes from the bore axis,...
03-20-2008, 11:05 AM -
