DCC Alignment
  • DCC Alignment
    What is the best way to set up your alignment for a bored hole in a cylindrical part?
    And when you level to the bore, what is that telling the CMM?
    I feel a lot better now that I've lost my mind.
    Global Activ
    PCDMIS CAD ++3.5 MR2
    When you level to a bore, you are telling the software to align an axis, whether X, Y or Z, to the axis or centerline of that bore.
    sigpic GDTPS - 0584
      Is this the best way to align a program that checks the diameter of a bored hole?
      Global Activ
        YEP, get yourself as square as possible to the bore to check the features of the bore (roundness, size, etc.) because it will give you the best possible approach vectors (as long as it is programmed correctly).
          Lvel, origin to cylinder, basically makes x,y,z = 0 (Squares everything).
            And would I still need a line for the x-rotate?
            Global Activ
              NO
              Kevin
                Originally posted by kmcmm View Post
                NO
                kmcmm is correct.
                But, this is only true for a cylindrical part.
                If there are other instances of not needing to use a rotation to lock in the part I'm sure an example will be coming soon.
                  Anything called out TP from this cylinder bore? If so you will need a rotation :P
                    Only one more thing, take a point on the end and set an origin on that. I dont trust axial origins on cylinders much like I dont trust setting parallel origins on planes
                      You are asking potentially open ended questions here. To 'measure' the feature is one thing. To 'report' the feature is another.
                      Sometimes in temp alignments you need to lock in a rotation. Sometimes you do not need to lock in a rotation. When reporting you always follow the Datum Scheme on the print.
                      Whether or not you lock in a rotation is feature dependant. With ROUND features, unless you need to map the surface then there is no need to lock a rotation to determine the size of the feature.
                      Bill Jarrells
                        Good point J.
                          On the end of what? It's a cylindrical part with a hole in the middle. Would the end be the top plane? If so, I already have that. I have the top plane set as my z-zero.
                          Global Activ
                            Well, in this case, the whole part and the feature in question IS round, and I'm only checking the hole diameter. So according to what you're saying, I don't need to lock a rotation .?. So once I set the cylinder axis to my z-level axis, and x & y zero, it should be ok?
                            Global Activ
                              Sorry... didnt see that in your original post on how to setup an alignment on a cylinder...
