Is there a way to configure PC-DMIS to setup any 3 gages (indifferent body positions) & run each program & print out a report, move on to the next gage, etc... at night when no one is around? If so, what kind of setup time would it take?
automatic gage checking
Originally posted by dlewis View PostIs there a way to configure PC-DMIS to setup any 3 gages (indifferent body positions) & run each program & print out a report, move on to the next gage, etc... at night when no one is around? If so, what kind of setup time would it take?
if it is the same gage then you could do it inside a single part program, if it is a different gage(without writing one hugh part part program) then you would need a master program of some sort to manage the different programs.
There are many threads in the forum that discuss this.
by UnderspecAnyone done any GAGE R & R's with PCDMIS? What was your repeatability? Range?
11-07-2006, 10:43 AM -
by dlewisIf I would like to set up a prgm to check multiple gages automatically at night when I am not there, can it be done? What would it take to configure the...
08-06-2007, 10:47 AM -
by D-TrainI've been asked to do a Gage R&R project using the CMM as the gage, and a step gage as the control subject. We are trying to determine the R&R...
06-05-2017, 09:41 PM -
by calbrittonI have two 2.25 class XXX setting gages. the ID of the Ring gage measures within .000010" of nominal but the Plug gage is measuring minus 000045"...
09-17-2016, 06:36 AM -
by Adrian23Hello,
I have a height gage with a 1.5mm step, I have measured both planes and I need the deviation between the two. Which function can I...-
10-08-2018, 06:51 AM -
