Good Morning,
I need verification on the method that PC DMIS uses to calculate the concentricity of a circle. This will be printed out for the Upper Mgt in an attempt to acquire a tolerance deviation. While I gave an answer, I need the support of this posting for my answer.
The question is:
When calculating concentricity is the deviation (ie.. dev = .900mm) a unilateral or a bilateral value? As a linear distance or a range?
Thanks in advance,
A.Gore
The question is:
Thanks in advance,
A.Gore
