So I have a bolt pattern w/ a composite FCF. No big deal, DIM TP, 2D BF alignment, and DIM TP. Run the program and the first set of TP dims are fine but the composite dims show 150 mm OOT. I monkey around w/ the show all param toggle field in th BF alignment and snap! the graphics display window shows everything jump into place! What gives?
Best fit alignment wackiness
by BIGWIG7I have a round part with 36x square slots broached into it. They are not clocked to anything but the req is they need to be equispaced to each other,...
01-05-2018, 02:41 PM -
by PowerJunkieAfter reading about some of you doing bestfit alignments I wanted to learn more about it. After consulting with the help menu it seems like this would...
10-31-2008, 11:10 AM -
by oriental_sunIs there somewhere you guys can recommend me to go to get some clairification on composite and pattern TP? I am having a really hard time with everyones...
05-16-2012, 10:47 PM -
by blind829Please view the attached GD&T. I know there's a simple answer and I should know this but how do you guys dimension out the 0.2 true position callout....
02-19-2009, 08:04 PM -
by Chally72I have an issue with a best-fit alignment throwing up an error when I run my program, one which promptly crashes pc-dmis after notifying me of the error....
07-06-2009, 11:09 AM -
