Is there a way to create a to create a code for chooseing just the probe positions you need. When the computers are set to operator mode and they choose the calibrate icon it does this for you. Does anyone know how to do this outside of creating a tool definition for every program?
Probe Marked Used ???
I think you may need to write a tip cal program that uses the appropriate tips. You could make that tip cal a marked set in each program. Each one would qualify the tips that your tip cal marked set called out.
I think it is called a parameter set.Last edited by craiger_ny; 08-14-2007, 05:05 PM.<internet bumper sticker goes here>
Originally posted by craiger_ny View PostI think you may need to write a tip cal program that uses the appropriate tips. You could make that tip cal a marked set in each program. Each one would qualify the tips that your tip cal marked set called out.Robert Horne
Va.
First create a calibration set in the probe utility window (selecting only the tips you wish to qualify/calibrate
Then go to the end of your program > autocalibrate > then toggle through or f9 it to get what you want
Then open the marked set window> double click >name it calibrate> clear all marked > mark only the auto calibrate
cntrl-s
execute marked set
Originally posted by spazus_maximus View PostFirst create a calibration set in the probe utility window (selecting only the tips you wish to qualify/calibrate
cntrl-s
execute marked set
This is the only option I get. Im useing 4.1Robert Horne
Va.
1. Open probe utility window
2. Select all the tips you will want to qualify
3. Click Measure
4. Go down to parameter sets & type in a name for this set > save
5. Exit the utility window
6. Go to end of program & insert autocalibrate command > f9 > select parameter set
7. Create Marked Set!
You should be good to go. Also you may want to create one parameter set with just AOBO and check the qual tool has moved box. Then leave this unchecked for the full parameter set
Except for the fact that it is a star probe, this might help.Last edited by JamesMannes; 10-23-2007, 10:14 AM.sigpic
3. Click Measure
You should be good to go. Also you may want to create one parameter set with just AOBO and check the qual tool has moved box. Then leave this unchecked for the full parameter setRobert Horne
Va.
by Chally72I am writing a program with several operations contained within the program. Say they are Op 10, Op 20, and Op 30. I created marked sets for these Ops,...
01-29-2009, 09:26 PM -
by Jonathan SI opened operator mode for the first time today to see how it looks and operates. It's time to start writing programs for others to run so they can do...
07-29-2008, 09:38 AM -
by ErikirI'm trying to create a marked set that will measure just one flatness feature on a part.
In my attempt to create a marked set, I highlighted...-
07-25-2013, 12:50 PM -
by AguayoI know I read something about lock Mark set in this forum,but I can't find it
in the set-up options there is a key to lock mark sets to prevent...-
06-23-2006, 10:51 AM -
by enviroCan someone let me in on a good procedure for creating Marked Sets? I do not know how to mark a set after reading the help (F1) it only left me wiyhout...
11-14-2008, 09:30 AM -
