Another tp call out?
There has to be more. You need some BASIC Dimensions that describe the relationship between the two. Is there a note to use the Model for Unspecified Dims? Maybe they meant for you to do that?Bill Jarrells
Originally posted by Wingman View PostThere has to be more. You need some BASIC Dimensions that describe the relationship between the two. Is there a note to use the Model for Unspecified Dims? Maybe they meant for you to do that?
Originally posted by Tested View PostNo there are BASICs for x, y & z. Sorry thought that to be a given. My question is if they want the TP of -H- but no rotation. Then where should my rotation come from.
I don't know your application but I get these from time to time when it really doesn't matter of the rotation is 'correct' as long as a mating module will mount to it.Last edited by Wingman; 08-14-2007, 01:22 PM.Bill Jarrells
Originally posted by craiger_ny View PostDo what we are doing and ask for clarification.
Align the feature based on the basic dimensions(rotate to the angle), then do the TP.
Originally posted by Tested View PostYeah that's where I'm headed. I just wanted to check see if I was having a brain fart before I went to the Engineer. YOU know I don't want him to point it out and get a big head. I have done it as a 2D and it looks like I'm making up numbersBill Jarrells
Originally posted by Tested View Postwon't that be |TP|Dia. 0.075|-K-|-F-|-H-| ?
Originally posted by cmmguy View PostIn a sense, but it also takes the rotational error out of the measurement. How else would you check the basic dimensions? Using 2D distance requires you to "make up" a dimension.
I would do it as CMMguy says here. Find the angle that the two basics create. Rotate to them. Rotate back the Basic Angle and report the two dimensions.
I misunderstood earlier and though you said there were NOT any Basic Dims.Last edited by Wingman; 08-14-2007, 01:45 PM.Bill Jarrells
Originally posted by Wingman View PostYep, the Basics simply define a POINT in space. Cartesian and Polar are two ways to say the same thing.
With a 2D think the rotation can float.
With a rotate the length can float.
They call it out with NO rotation. That why I'm thinking 2D.
Originally posted by Wingman View PostI misunderstood earlier and though you said there were NOT any Basic Dims.<internet bumper sticker goes here>
by DungTPlease see attached dwg. (not to scale)
Since there is only one basic dimension between the two holes, and the dwg called out TP...-
02-07-2011, 10:04 PM -
by Chally72I left my profile on for another operator last night, and I just sat down to write a program, and when I put in a TP dimension, it stuck the TP line right...
02-20-2009, 05:33 PM -
by MeglaHi guys!
Need some hints about TP on picture attached below.
Is that position applies to zeros (0) on drawings, or it show position...-
12-03-2013, 09:34 AM -
by j.gonzalezso i have a slot .630 +/- .0005 by .254 +/- .0005 with a true position of .004 to c/l what is the proper way to check I think i'm checking it right but...
07-23-2009, 07:17 PM -
by NikoMHello to everybody.
Use to run into that issue before, but I would ask you to remind me what I should be aware if I want to report TP for...-
05-15-2006, 03:13 PM -
