Hello to all. I came in to work this morning and someone dumped my main probe file. Is there any way I can recover my old probe file with out starting a new one ?
Copy it back to the PC from teh backups that you should be doing?
Look in the recycle bin to see if it is there?
e a DOS boot and use recover (very hard to do, only the old DOS users can probably do this and probably also if the ahrd drive isn't too big).
Are you saying they went into your folder that pc-dmis is in and deleted your probe files. If they did then do what matt said. If they are still if the folder then make sure your search path is set to look for them.
I just made it up, all on my own. I sat there and guessed/tried/solved what all the 'stuff' meant so I could make some customer probes of my own. Did this WAY BACK before they even had the most of the stuf in there (like, V3.2063). One setup I had to use involved using a knuckle and there was no option in the file for it, so I had to make my own.
hey guys, i'm new to the forum so if this question has been asked a ton of times i appologize. my question is we are running a program on a different...
I've deleted probe files in the past and re-created them, but this morning it won't let me. I go to Explorer, go to the probe files folder, delete the...
In the middle of writing a program using a probe that is difine and used alot. PCDMIS errored and shut down, went back to the program and now it is saying...
Hi all, I received the probe file for a disc probe I purchased in a .txt format. I copied and pasted it to my 2017R1 folder on the C drive. I then converted...
