Can't get a machine start help!
  • Can't get a machine start help!
    Well my PFX was disconnected from the air supply and now its reconnected again.However I can't get the machine start light to stay on.I've tried hitting and releasing the red panic button a few times.I also shut down the PC and CMM a few times with little success.
    One thing I did notice is that the light on the Renishaw PH10T probehead is not on.Also there doesn't seem to be any power to the Probe Head Controller,as there are no lights on in that either.
    Any suggestions would be greatly appreciated. As usual of course there's a hot job waiting to be checked. Thanks!
    Cycle power on the probe head controller. It should be lit up.
    Bill Jarrells
      Check to see that you have gas in the tank and air in the tires.
      Actually, Does the machine have a power strip, or as some people call them, "surge protector"? Check to make sure that it is on.
        Turn controller off and do a restart. Also check to make sure you have enough air pressure. Depending on machine it should be somewhere between 60 and 80 PSI
          Last fall my global image wouldn't consistantly start up and it was driving me nuts. It turns out that it was because of a $5 10/100 Network card not functioning properly in the PC. It wasn't seated in the slot or was making intermitent connection with the mainboard, not allowing it to communicate with the CMM controller. I pulled it out cleaned the contacts and reseated it in the mainboard.....problem solved.
            Does your RCU have a "Mach. Start" button? This activates my probe head.
              I have a small HCU1 displat box that usually has something on it,but as of right now nothing at all.Now If I touch the actual tip I get a beep,but no light on the probehead for the "hit". I also checked the fuses on the probe controller box,but they appear to be fine.
              Doesn't the light on the probe head usually stay on,until a hit is taken?
              All I can say is ,this is one heck of a way to start a Monday!
                Henger, you had that happen to your PFx some time ago. Do you remember what was wrong with it?
                PCDMIS 2012
                Windows Office XP
                  On the jog box hit the "enable" button twice? If that doesn't do anything try the "probe enable" button? I can't remember which one it is but see if either of those does anything for you.
                    Do You Have a magnetic tp20 Probe module? I had this problem not to long ago and that was the trouble My probe module Had been Crashed on one of the off shifts and Destroyed internally. I'm told these will sometimes just go Bad Something to look at if you have an extra or a probe changer.
                    sigpicTHE TASK AHEAD OF YOU, IS NEVER AS GREAT AS THE POWER BEHIND YOU. I Fight for Freedom and Pray For Peace..
                      TP200 is bad for this. I did not know the TP20 had this problem. Hmm.
                      Bill Jarrells
                        I've seen a TP20 module leaking before.
                          Yeah same here.
                          But, I thought they worked like a TP2 with an added magnetic base to allow an automaitic probe changer and not like a TP 200. Hmm. I thought the TP 200 used a different triggering and the casing was lined with magnets. If the TP200 takes a 'hit' it can dislodge the magnets and render it useless. I thought the TP 20 was diff technology?
                          Bill Jarrells
                            Yes the TP20 does have a magnetic base for probe changer capability. And in theory it should dislodge when crashed. I don't think it works when it drives straight down the Z axis though. I've seen fish hooks made from probe tips before.
                              I had the air go off on one machine with a tp20 on it crash it sent it about 15ft up and off the wall Crushed the sleeve even all the way around. I got to order an extra one for just in case. The machine is down now they don't want to pay to fix all the airlines for the use it gets an ol manual machine with MM3 on it and versions behind at that...lol
                              • kstad
                                CMM dead
                                by kstad
                                I have a Brown and Sharp Micro Val PFX I am using, while at lunch not being used I came back from the machine and it went into emergancy shut down. The...
                                04-28-2008, 01:27 PM
                              • Chally72
                                Servos won't Power On
                                by Chally72
                                So it's Friday afternoon, I settle in to start doing some programming before going home. All of a sudden, as I'm editing a program, the controller sounds...
                                05-22-2009, 06:11 PM
                              • Cookie
                                Monday's
                                by Cookie
                                Morning all ,
                                Came in to a machine down this morning. It will not even power the servos up.
                                Any one have any ideas?...
                                05-24-2010, 11:19 AM
                              • bigtallanddopey
                                CMM wont start,
                                by bigtallanddopey
                                HI people, hoping you can help me out here.
                                Everything was working fine yesterday, came in this morning and switched the CMM on and waited...
                                06-03-2015, 06:28 AM
                              • Ben1989
                                Machine Motor Won't Enable
                                by Ben1989
                                Hi guys,
                                Sorry to come on here with mechanical/machine issues but I'm going crazy as to why our CMM's motor won't enable. You'll have to...
                                02-21-2017, 09:47 AM
