I've created a line between two circles to align the x-plus axis on (Dmis doesn't like aligning to a single circle so i find it best to create a line between the two). This works fine first time. I then move the part through 180 degrees for calibration check of the machine and the line's vector changes to go in the opposite direction (x-minus)!!
If I update the line with exactly the same circles in the same order as it already was, it will then change the vector of the line to how it should be!! I've tried recreating the circles, the lines and i've also used the values from the circles and put them into generic points, but nothing is working!!
Any ideas??
Ta
Any ideas??
Ta
