If I took three points on a part that has a half circle and PC DMIS recognized it as a circle.....what feature do I use to print out the Radius of the half circle. I knoiw using an optical comparator would be easier, but we dont have that equipment here in the facility. Any suggestions on what I need to do?
Radius....
Originally posted by emurray View PostIf I took three points on a part that has a half circle and PC DMIS recognized it as a circle.....what feature do I use to print out the Radius of the half circle. I knoiw using an optical comparator would be easier, but we dont have that equipment here in the facility. Any suggestions on what I need to do?
You need more than just three hits.sigpic GDTPS - 0584
First of all, 3 hits will ALWAYS make a perfect circle. THe problem with that is you have no idea if ALL the hits were good. 4 or more will give you a roundness value as well and it will help indicate if you had a bad hit (high roundness value wouold be suspect).
To print out the radius, simple DIMENSION ~ LOCATION the circle and select R for the axis, which will give you the radius. If you are worried that Pcdmis is showing (graphically) a full circle, don't worry about it.sigpic
I always take at least 10 hits on a circle, even if its only on a 60° radius. I know they will be redundant, but its better than getting a single bad hit that moves the circle center location. More hits= less movement on that one bad hit.
I still like to use the icons for some things. The red icon that looks like a square with a plus sign in the middle will give you the report menu for feature location.
In the middle section, there is a box titled "Axes".
Unclick the radio button at the top marked "Auto" (this comes up by default, and tends to give you diameter, when dealing with a circle, and your x, y or z values, based on work plane).
Click the radio button beside "R".
click on the apropriate circle from the features box on the left (I always do this after changing the AXES box because if you do it first, the Auto Axis will click a bunch of stuff you will have to undo).
Make sure that you put the nominal data for a circle DIAMETER in the box for nominal size, under ISO Limits. DMIS will report out half value of whatever is in this box.
Put in your upper (plus) and lower (minus) tolerances (double print tolerance - again, DMIS will report half of what is in these boxes).
Click the "Create" button.
Originally posted by bfire85 View PostI was married for 1 month when this thread was started!(In Memory of my Loving wife, "Ronda" who I lost March 7, 2016. I love you baby.)They say "Nobody's Perfect." I must be Nobody.
Ahhh... I was a freshman to the Demon in '07. I still don't miss that MIP on that little PFX.Horizontals - Dual Arm 40-17-21 / Single Arm 30-14-16 - PCD 2013MR1 (64bit)
by BuckeyeI am not having much luck finding help on this, so I will start a new thread. I am measuring a diesel crankshaft, and need to find the tangency point...
05-07-2008, 04:16 PM -
by JLHUTTI have a part that is shaped like a cylinder with a hole in the middle. At the top of the ID it looks like an hour glass, tapers outward then straight...
11-29-2007, 05:55 PM -
by dennisgilpinHi there, I'm trying to find out what is the best way to measure this 1mm radius on the side of my part. I'm using a .5mmx20 probe, taking 8 hits on radius....
03-05-2013, 11:43 AM -
by tiborsomogyiHi Everybody!
I have a square model with equal radius circle in all corners. I want to measure the 4 radius, but i cant... I'm trying with constructed...-
03-19-2013, 04:27 AM -
by mconklinI have always checked a radius breakout manually on a height gage. But we have a part to check that is too long and was wondering if anybody has done...
09-29-2010, 11:42 AM -
