I am brand new to the PC-DMIS software in Greensboro NC. My background is working with the Zeiss CMM and Calypso software which seems to be a little more user- friendly. I have been following the manual step for step and have accomplished in writing a test program. However, when I go to run the program, a fault appears and tells me that the parameters are out of tolerance. I have tried what little I know about this software and nothing seems to work. I need some help here.
Parameter Trouble
Does it say Machine Parameters Out of Tolerance?
It could be that you have an alignment issue.
Also, if your part is to close to the edges of the measurement envelope, this will come up.
Can you post the beginning of your code?When in doubt, post code. A second set of eyes might see something you missed.
It sounds like you might be defining a feature or move point that is out of the machine tolerance. Like John K. said, you could be too close to the measurement envelope. There is a soft zone where you can manually move your probe but dcc won't allow due to safety precautions.I used to be high on life but I built up a tolerance.
Originally posted by emurray View PostThe error I keep getting is TR_OUTOL. I am writing the program in "manual" mode. Where can I find the "envelope" because the part is sitting more to the right of the table versus the center.
We were talking more to the edge of the machine. View your graphics display and see that all features are located appropriately around the datum.
When you get the error, and cancel the program, a red arrow should appear next to the feature in question. Double check that feature to see that the x,y,z locations are correct.I used to be high on life but I built up a tolerance.
Here is a copy of the test program that I am trying to write. Please keep in mind that this is my second day uising this software and it is nothing like calypso. I used some basic features and alignments. PLEASE HELP
RECALL/ALIGNMENT,INTERNAL, ALIGNMENT/TRANS,YAXIS,CIR1 ALIGNMENT/TRANS,XAXIS,CIR1 ALIGNMENT/TRANS,ZAXIS,PLN1 ALIGNMENT/LEVEL,ZPLUS,PLN1A2 =ALIGNMENT/START,RECALL:STARTUP, LIST= YES
ALIGNMENT/ENDTP MMC 0.0000 0.0000 0.0052 164.8219 0.0052 -------->D2 0.4473 0.0000 0.0000 0.4470 CIRCLE CIR2 AT RFS D1 0.4465 0.0000 0.0000 0.4467 CIRCLE CIR4 AT RFS DF 0.4451 0.0000 0.0000 0.0000 0.4503 0.0052 0.0052 -------->Y 12.4934 12.4941 0.0007 X 15.6724 15.6699 -0.0025 DIM LOC1= TRUE POSITION OF CIRCLE CIR3 UNITS=IN ,$
GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH DEV PERPEN CENTERLINE=OFF DISPLAY=DIAMETER
AX NOMINAL +TOL -TOL BONUS MEAS DEV DEVANG OUTTOL
END OF DIMENSION LOC1 HIT/BASIC,NORMAL,12.794,7.7396,-17.6873,0.6650065,-0.7468376,0,12.8003,7.7452,-17.7381,USE THEO = YES HIT/BASIC,NORMAL,13.0433,7.3762,-17.6873,-0.4572583,0.8893339,0,13.0411,7.3751,-17.7381,USE THEO = YES HIT/BASIC,NORMAL,12.7713,7.4277,-17.6873,0.759656,0.6503252,0,12.7479,7.4596,-17.7381,USE THEO = YES HIT/BASIC,NORMAL,13.1338,7.6895,-17.6873,-0.8563899,-0.5163297,0,13.1316,7.6922,-17.7381,USE THEO = YES MOVE/CLEARPLANECIR4 =FEAT/CIRCLE,RECT,IN,LEAST_SQR
THEO/12.9418,7.5737,-17.6873,0,0,1,0.4465
ACTL/12.9411,7.5735,-17.7381,0,0,1,0.4467
MEAS/CIRCLE,4,WORKPLANE
MOVE/CLEARPLANE
ENDMEAS/ HIT/BASIC,NORMAL,15.4514,12.5083,-17.7499,0.9977298,-0.0673444,0,15.4457,12.4704,-17.7224,USE THEO = YES HIT/BASIC,NORMAL,15.8933,12.5083,-17.7498,-0.9977194,-0.0674981,0,15.8936,12.4704,-17.7223,USE THEO = YES HIT/BASIC,NORMAL,15.6915,12.7163,-17.7498,-0.0850857,-0.9963736,0,15.6902,12.3072,-17.7223,USE THEO = YES HIT/BASIC,NORMAL,15.6813,12.27,-17.7497,-0.0394931,0.9992198,0,15.6893,12.6802,-17.7223,USE THEO = YES MOVE/CLEARPLANECIR3 =FEAT/CIRCLE,RECT,IN,LEAST_SQR
THEO/15.6724,12.4934,-17.7498,0,0,1,0.4451
ACTL/15.6697,12.4937,-17.7223,0,0,1,0.4503
MOVE/CLEARPLANE
ENDMEAS/ HIT/BASIC,NORMAL,18.2834,7.4699,-17.6992,0.3426368,0.9394679,0,18.2637,7.4788,-17.6778,USE THEO = YES HIT/BASIC,NORMAL,18.5713,7.751,-17.6991,-0.9475703,-0.3195474,0,18.531,7.8193,-17.6777,USE THEO = YES HIT/BASIC,NORMAL,18.1734,7.8036,-17.6992,0.8330036,-0.5532675,0,18.1596,7.7793,-17.6778,USE THEO = YES HIT/BASIC,NORMAL,18.5667,7.5927,-17.6991,-0.9217923,0.3876841,0,18.5627,7.5818,-17.6778,USE THEO = YES MOVE/CLEARPLANECIR2 =FEAT/CIRCLE,RECT,IN,LEAST_SQR
THEO/18.3599,7.6797,-17.6992,0,0,1,0.4473
ACTL/18.3601,7.6791,-17.6778,0,0,1,0.447
MOVE/CLEARPLANE
ENDMEAS/ HIT/BASIC,NORMAL,14.3674,9.3373,-17.5305,0.9998593,-0.0167717,0,14.3697,9.2986,-17.6012,USE THEO = YES HIT/BASIC,NORMAL,16.8721,9.3375,-17.5305,-0.9998575,-0.0168806,0,16.8697,9.2707,-17.6012,USE THEO = YES HIT/BASIC,NORMAL,15.5312,8.0772,-17.5305,0.0715583,0.9974364,0,15.4239,10.5031,-17.6013,USE THEO = YES HIT/BASIC,NORMAL,15.5311,10.5553,-17.5306,0.0717007,-0.9974262,0,15.6321,8.1139,-17.6011,USE THEO = YES MOVE/CLEARPLANECIR1 =FEAT/CIRCLE,RECT,IN,LEAST_SQR
THEO/15.6201,9.3163,-17.5305,0,0,1,2.4947
ACTL/15.6205,9.3163,-17.6012,0,0,1,2.4905
MOVE/CLEARPLANE
ENDMEAS/ HIT/BASIC,NORMAL,15.7211,6.849,-17.0947,-0.0127343,0.0015754,0.9999177,15.721,6.8489,-17.0921,USE THEO = YES HIT/BASIC,NORMAL,18.0435,9.1007,-17.0686,-0.0127343,0.0015754,0.9999177,18.0434,9.1007,-17.0648,USE THEO = YES HIT/BASIC,NORMAL,15.1793,11.6246,-17.1091,-0.0127343,0.0015754,0.9999177,17.3267,11.063,-17.0886,USE THEO = YES MOVE/CLEARPLANEPLN1 =FEAT/PLANE,RECT,TRIANGLE
THEO/16.3147,9.1915,-17.0908,-0.0127343,0.0015754,0.9999177
ACTL/15.5484,9.1693,-17.0866,0.0031603,-0.0018859,0.9999932
MEAS/PLANE,3
MOVE/CLEARPLANE
ENDMEAS/ TIP/T1A0B0, SHANKIJK=0, 0, 1, ANGLE=0 LOADPROBE/1MM_20SHANK_40EXT FLY/ON,0.1181 TOUCHSPEED/ 1.2 MOVESPEED/ 100 COMMENT/OPER,NO,Warning! Machine will be in "DCC" mode. MOVESPEED/ 50 CLEARP/ZPLUS,0.5,ZPLUS,0 FORMAT/TEXT,OPTIONS,ID,HEADINGS,SYMBOLS, ;NOM,TOL,MEAS,MAXMIN,DEV,DEVANG,OUTTOL MODE/DCC MOVESPEED/ 50 FORMAT/TEXT,OPTIONS,ID,HEADINGS,SYMBOLS, ;NOM,TOL,MEAS,MAXMIN,DEV,DEVANG,OUTTOL CLEARP/ZPLUS,0.5,ZPLUS,0STARTUP =ALIGNMENT/START,RECALL:, LIST= YES
ALIGNMENT/ENDPART NAME : Test
REV NUMBER :
SER NUMBER :
STATS COUNT : 1
ALIGNMENT/END FORMAT/TEXT,OPTIONS,ID,HEADINGS,SYMBOLS, ;NOM,TOL,MEAS,MAXMIN,DEV,DEVANG,OUTTOL
Originally posted by emurray View PostHere is a copy of the test program that I am trying to write. Please keep in mind that this is my second day uising this software and it is nothing like calypso. I used some basic features and alignments. PLEASE HELP
Code:RECALL/ALIGNMENT,INTERNAL, ALIGNMENT/TRANS,YAXIS,CIR1 ALIGNMENT/TRANS,XAXIS,CIR1 ALIGNMENT/TRANS,ZAXIS,PLN1 ALIGNMENT/LEVEL,ZPLUS,PLN1A2 =ALIGNMENT/START,RECALL:STARTUP, LIST= YES ALIGNMENT/LEVEL,ZPLUS,PLN1 ALIGNMENT/TRANS,ZAXIS,PLN1 ALIGNMENT/TRANS,XAXIS,CIR1 ALIGNMENT/TRANS,YAXIS,CIR1 ALIGNMENT/ENDTP MMC 0.0000 0.0000 0.0052 164.8219 0.0052 -------->D2 0.4473 0.0000 0.0000 0.4470 CIRCLE CIR2 AT RFS D1 0.4465 0.0000 0.0000 0.4467 CIRCLE CIR4 AT RFS DF 0.4451 0.0000 0.0000 0.0000 0.4503 0.0052 0.0052 -------->Y 12.4934 12.4941 0.0007 X 15.6724 15.6699 -0.0025 DIM LOC1= TRUE POSITION OF CIRCLE CIR3 UNITS=IN ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH DEV PERPEN CENTERLINE=OFF DISPLAY=DIAMETER AX NOMINAL +TOL -TOL BONUS MEAS DEV DEVANG OUTTOL X 15.6724 15.6699 -0.0025 Y 12.4934 12.4941 0.0007 DF 0.4451 0.0000 0.0000 0.0000 0.4503 0.0052 0.0052 --------> D1 0.4465 0.0000 0.0000 0.4467 CIRCLE CIR4 AT RFS D2 0.4473 0.0000 0.0000 0.4470 CIRCLE CIR2 AT RFS TP MMC 0.0000 0.0000 0.0052 164.8219 0.0052 --------> END OF DIMENSION LOC1 HIT/BASIC,NORMAL,12.794,7.7396,-17.6873,0.6650065,-0.7468376,0,12.8003,7.7452,-17.7381,USE THEO = YES HIT/BASIC,NORMAL,13.0433,7.3762,-17.6873,-0.4572583,0.8893339,0,13.0411,7.3751,-17.7381,USE THEO = YES HIT/BASIC,NORMAL,12.7713,7.4277,-17.6873,0.759656,0.6503252,0,12.7479,7.4596,-17.7381,USE THEO = YES HIT/BASIC,NORMAL,13.1338,7.6895,-17.6873,-0.8563899,-0.5163297,0,13.1316,7.6922,-17.7381,USE THEO = YES MOVE/CLEARPLANECIR4 =FEAT/CIRCLE,RECT,IN,LEAST_SQR THEO/12.9418,7.5737,-17.6873,0,0,1,0.4465 ACTL/12.9411,7.5735,-17.7381,0,0,1,0.4467 MEAS/CIRCLE,4,WORKPLANE MOVE/CLEARPLANE HIT/BASIC,NORMAL,13.1338,7.6895,-17.6873,-0.8563899,-0.5163297,0,13.1316,7.6922,-17.7381,USE THEO = YES HIT/BASIC,NORMAL,12.7713,7.4277,-17.6873,0.759656,0.6503252,0,12.7479,7.4596,-17.7381,USE THEO = YES HIT/BASIC,NORMAL,13.0433,7.3762,-17.6873,-0.4572583,0.8893339,0,13.0411,7.3751,-17.7381,USE THEO = YES HIT/BASIC,NORMAL,12.794,7.7396,-17.6873,0.6650065,-0.7468376,0,12.8003,7.7452,-17.7381,USE THEO = YES ENDMEAS/ HIT/BASIC,NORMAL,15.4514,12.5083,-17.7499,0.9977298,-0.0673444,0,15.4457,12.4704,-17.7224,USE THEO = YES HIT/BASIC,NORMAL,15.8933,12.5083,-17.7498,-0.9977194,-0.0674981,0,15.8936,12.4704,-17.7223,USE THEO = YES HIT/BASIC,NORMAL,15.6915,12.7163,-17.7498,-0.0850857,-0.9963736,0,15.6902,12.3072,-17.7223,USE THEO = YES HIT/BASIC,NORMAL,15.6813,12.27,-17.7497,-0.0394931,0.9992198,0,15.6893,12.6802,-17.7223,USE THEO = YES MOVE/CLEARPLANECIR3 =FEAT/CIRCLE,RECT,IN,LEAST_SQR THEO/15.6724,12.4934,-17.7498,0,0,1,0.4451 ACTL/15.6697,12.4937,-17.7223,0,0,1,0.4503 MEAS/CIRCLE,4,WORKPLANE MOVE/CLEARPLANE HIT/BASIC,NORMAL,15.6813,12.27,-17.7497,-0.0394931,0.9992198,0,15.6893,12.6802,-17.7223,USE THEO = YES HIT/BASIC,NORMAL,15.6915,12.7163,-17.7498,-0.0850857,-0.9963736,0,15.6902,12.3072,-17.7223,USE THEO = YES HIT/BASIC,NORMAL,15.8933,12.5083,-17.7498,-0.9977194,-0.0674981,0,15.8936,12.4704,-17.7223,USE THEO = YES HIT/BASIC,NORMAL,15.4514,12.5083,-17.7499,0.9977298,-0.0673444,0,15.4457,12.4704,-17.7224,USE THEO = YES ENDMEAS/ HIT/BASIC,NORMAL,18.2834,7.4699,-17.6992,0.3426368,0.9394679,0,18.2637,7.4788,-17.6778,USE THEO = YES HIT/BASIC,NORMAL,18.5713,7.751,-17.6991,-0.9475703,-0.3195474,0,18.531,7.8193,-17.6777,USE THEO = YES HIT/BASIC,NORMAL,18.1734,7.8036,-17.6992,0.8330036,-0.5532675,0,18.1596,7.7793,-17.6778,USE THEO = YES HIT/BASIC,NORMAL,18.5667,7.5927,-17.6991,-0.9217923,0.3876841,0,18.5627,7.5818,-17.6778,USE THEO = YES MOVE/CLEARPLANECIR2 =FEAT/CIRCLE,RECT,IN,LEAST_SQR THEO/18.3599,7.6797,-17.6992,0,0,1,0.4473 ACTL/18.3601,7.6791,-17.6778,0,0,1,0.447 MEAS/CIRCLE,4,WORKPLANE MOVE/CLEARPLANE HIT/BASIC,NORMAL,18.5667,7.5927,-17.6991,-0.9217923,0.3876841,0,18.5627,7.5818,-17.6778,USE THEO = YES HIT/BASIC,NORMAL,18.1734,7.8036,-17.6992,0.8330036,-0.5532675,0,18.1596,7.7793,-17.6778,USE THEO = YES HIT/BASIC,NORMAL,18.5713,7.751,-17.6991,-0.9475703,-0.3195474,0,18.531,7.8193,-17.6777,USE THEO = YES HIT/BASIC,NORMAL,18.2834,7.4699,-17.6992,0.3426368,0.9394679,0,18.2637,7.4788,-17.6778,USE THEO = YES ENDMEAS/ HIT/BASIC,NORMAL,14.3674,9.3373,-17.5305,0.9998593,-0.0167717,0,14.3697,9.2986,-17.6012,USE THEO = YES HIT/BASIC,NORMAL,16.8721,9.3375,-17.5305,-0.9998575,-0.0168806,0,16.8697,9.2707,-17.6012,USE THEO = YES HIT/BASIC,NORMAL,15.5312,8.0772,-17.5305,0.0715583,0.9974364,0,15.4239,10.5031,-17.6013,USE THEO = YES HIT/BASIC,NORMAL,15.5311,10.5553,-17.5306,0.0717007,-0.9974262,0,15.6321,8.1139,-17.6011,USE THEO = YES MOVE/CLEARPLANECIR1 =FEAT/CIRCLE,RECT,IN,LEAST_SQR THEO/15.6201,9.3163,-17.5305,0,0,1,2.4947 ACTL/15.6205,9.3163,-17.6012,0,0,1,2.4905 MEAS/CIRCLE,4,WORKPLANE MOVE/CLEARPLANE HIT/BASIC,NORMAL,15.5311,10.5553,-17.5306,0.0717007,-0.9974262,0,15.6321,8.1139,-17.6011,USE THEO = YES HIT/BASIC,NORMAL,15.5312,8.0772,-17.5305,0.0715583,0.9974364,0,15.4239,10.5031,-17.6013,USE THEO = YES HIT/BASIC,NORMAL,16.8721,9.3375,-17.5305,-0.9998575,-0.0168806,0,16.8697,9.2707,-17.6012,USE THEO = YES HIT/BASIC,NORMAL,14.3674,9.3373,-17.5305,0.9998593,-0.0167717,0,14.3697,9.2986,-17.6012,USE THEO = YES ENDMEAS/ HIT/BASIC,NORMAL,15.7211,6.849,-17.0947,-0.0127343,0.0015754,0.9999177,15.721,6.8489,-17.0921,USE THEO = YES HIT/BASIC,NORMAL,18.0435,9.1007,-17.0686,-0.0127343,0.0015754,0.9999177,18.0434,9.1007,-17.0648,USE THEO = YES HIT/BASIC,NORMAL,15.1793,11.6246,-17.1091,-0.0127343,0.0015754,0.9999177,17.3267,11.063,-17.0886,USE THEO = YES MOVE/CLEARPLANEPLN1 =FEAT/PLANE,RECT,TRIANGLE THEO/16.3147,9.1915,-17.0908,-0.0127343,0.0015754,0.9999177 ACTL/15.5484,9.1693,-17.0866,0.0031603,-0.0018859,0.9999932 MEAS/PLANE,3 MOVE/CLEARPLANE HIT/BASIC,NORMAL,15.1793,11.6246,-17.1091,-0.0127343,0.0015754,0.9999177,17.3267,11.063,-17.0886,USE THEO = YES HIT/BASIC,NORMAL,18.0435,9.1007,-17.0686,-0.0127343,0.0015754,0.9999177,18.0434,9.1007,-17.0648,USE THEO = YES HIT/BASIC,NORMAL,15.7211,6.849,-17.0947,-0.0127343,0.0015754,0.9999177,15.721,6.8489,-17.0921,USE THEO = YES ENDMEAS/ TIP/T1A0B0, SHANKIJK=0, 0, 1, ANGLE=0 LOADPROBE/1MM_20SHANK_40EXT FLY/ON,0.1181 TOUCHSPEED/ 1.2 MOVESPEED/ 100 COMMENT/OPER,NO,Warning! Machine will be in "DCC" mode. MOVESPEED/ 50 CLEARP/ZPLUS,0.5,ZPLUS,0 FORMAT/TEXT,OPTIONS,ID,HEADINGS,SYMBOLS, ;NOM,TOL,MEAS,MAXMIN,DEV,DEVANG,OUTTOL MODE/DCC MOVESPEED/ 50 FORMAT/TEXT,OPTIONS,ID,HEADINGS,SYMBOLS, ;NOM,TOL,MEAS,MAXMIN,DEV,DEVANG,OUTTOL CLEARP/ZPLUS,0.5,ZPLUS,0STARTUP =ALIGNMENT/START,RECALL:, LIST= YES ALIGNMENT/ENDPART NAME : Test REV NUMBER : SER NUMBER : STATS COUNT : 1 STARTUP =ALIGNMENT/START,RECALL:, LIST= YES ALIGNMENT/END FORMAT/TEXT,OPTIONS,ID,HEADINGS,SYMBOLS, ;NOM,TOL,MEAS,MAXMIN,DEV,DEVANG,OUTTOL
Is that exactly how it appears in pc-dmis??? It is kind of backwards.
I just copy and pasted and this is what I got. I took 3 hits on the top plane, 4 hits on circle 1, 2, 3, and 4. Then did an alignment for the last 3 circles. Set my speeds and clearance planes and that was it. I dont why it didnt post that way
Why don't you try that again. This time wrap what you past in [code][/code] tags. That way it will look more like pc-dmis looks. Start by highlighting from the start of your program to the end, copy it and paste it.
ie, when you post make it look like the following.
[code] paste stuff here [/code]
Your code looks all funny. The bit that posted at the end should be right up at the top of your program.
Here is the program again
PART NAME : Test
REV NUMBER :
SER NUMBER :
STATS COUNT : 1
ALIGNMENT/END
MOVESPEED/ 50
MODE/DCC
MOVESPEED/ 50
MOVESPEED/ 100
TOUCHSPEED/ 1.2
FLY/ON,0.1181
MEAS/PLANE,3
MOVE/CLEARPLANE
ENDMEAS/
MOVE/CLEARPLANE
ENDMEAS/
MOVE/CLEARPLANE
ENDMEAS/
MOVE/CLEARPLANE
ENDMEAS/
MOVE/CLEARPLANE
ENDMEAS/
ALIGNMENT/END
Originally posted by emurray View PostCode:PART NAME : Test REV NUMBER : SER NUMBER : STATS COUNT : 1 STARTUP =ALIGNMENT/START,RECALL:, LIST= YES ALIGNMENT/END CLEARP/ZPLUS,0.5,ZPLUS,0 FORMAT/TEXT,OPTIONS,ID,HEADINGS,SYMBOLS, ;NOM,TOL,MEAS,MAXMIN,DEV,DEVANG,OUTTOL MOVESPEED/ 50 FORMAT/TEXT,OPTIONS,ID,HEADINGS,SYMBOLS, ;NOM,TOL,MEAS,MAXMIN,DEV,DEVANG,OUTTOL MODE/DCC FORMAT/TEXT,OPTIONS,ID,HEADINGS,SYMBOLS, ;NOM,TOL,MEAS,MAXMIN,DEV,DEVANG,OUTTOL CLEARP/ZPLUS,0.5,ZPLUS,0 MOVESPEED/ 50 COMMENT/OPER,NO,Warning! Machine will be in "DCC" mode. MOVESPEED/ 100 TOUCHSPEED/ 1.2 FLY/ON,0.1181 LOADPROBE/1MM_20SHANK_40EXT TIP/T1A0B0, SHANKIJK=0, 0, 1, ANGLE=0 PLN1 =FEAT/PLANE,RECT,TRIANGLE THEO/16.3147,9.1915,-17.0908,-0.0127343,0.0015754,0.9999177 ACTL/15.5484,9.1693,-17.0866,0.0031603,-0.0018859,0.9999932 MEAS/PLANE,3 MOVE/CLEARPLANE HIT/BASIC,NORMAL,15.1793,11.6246,-17.1091,-0.0127343,0.0015754,0.9999177,17.3267,11.063,-17.0886,USE THEO = YES HIT/BASIC,NORMAL,18.0435,9.1007,-17.0686,-0.0127343,0.0015754,0.9999177,18.0434,9.1007,-17.0648,USE THEO = YES HIT/BASIC,NORMAL,15.7211,6.849,-17.0947,-0.0127343,0.0015754,0.9999177,15.721,6.8489,-17.0921,USE THEO = YES ENDMEAS/ CIR1 =FEAT/CIRCLE,RECT,IN,LEAST_SQR THEO/15.6201,9.3163,-17.5305,0,0,1,2.4947 ACTL/15.6205,9.3163,-17.6012,0,0,1,2.4905 MEAS/CIRCLE,4,WORKPLANE MOVE/CLEARPLANE HIT/BASIC,NORMAL,15.5311,10.5553,-17.5306,0.0717007,-0.9974262,0,15.6321,8.1139,-17.6011,USE THEO = YES HIT/BASIC,NORMAL,15.5312,8.0772,-17.5305,0.0715583,0.9974364,0,15.4239,10.5031,-17.6013,USE THEO = YES HIT/BASIC,NORMAL,16.8721,9.3375,-17.5305,-0.9998575,-0.0168806,0,16.8697,9.2707,-17.6012,USE THEO = YES HIT/BASIC,NORMAL,14.3674,9.3373,-17.5305,0.9998593,-0.0167717,0,14.3697,9.2986,-17.6012,USE THEO = YES ENDMEAS/ CIR2 =FEAT/CIRCLE,RECT,IN,LEAST_SQR THEO/18.3599,7.6797,-17.6992,0,0,1,0.4473 ACTL/18.3601,7.6791,-17.6778,0,0,1,0.447 MEAS/CIRCLE,4,WORKPLANE MOVE/CLEARPLANE HIT/BASIC,NORMAL,18.5667,7.5927,-17.6991,-0.9217923,0.3876841,0,18.5627,7.5818,-17.6778,USE THEO = YES HIT/BASIC,NORMAL,18.1734,7.8036,-17.6992,0.8330036,-0.5532675,0,18.1596,7.7793,-17.6778,USE THEO = YES HIT/BASIC,NORMAL,18.5713,7.751,-17.6991,-0.9475703,-0.3195474,0,18.531,7.8193,-17.6777,USE THEO = YES HIT/BASIC,NORMAL,18.2834,7.4699,-17.6992,0.3426368,0.9394679,0,18.2637,7.4788,-17.6778,USE THEO = YES ENDMEAS/ CIR3 =FEAT/CIRCLE,RECT,IN,LEAST_SQR THEO/15.6724,12.4934,-17.7498,0,0,1,0.4451 ACTL/15.6697,12.4937,-17.7223,0,0,1,0.4503 MEAS/CIRCLE,4,WORKPLANE MOVE/CLEARPLANE HIT/BASIC,NORMAL,15.6813,12.27,-17.7497,-0.0394931,0.9992198,0,15.6893,12.6802,-17.7223,USE THEO = YES HIT/BASIC,NORMAL,15.6915,12.7163,-17.7498,-0.0850857,-0.9963736,0,15.6902,12.3072,-17.7223,USE THEO = YES HIT/BASIC,NORMAL,15.8933,12.5083,-17.7498,-0.9977194,-0.0674981,0,15.8936,12.4704,-17.7223,USE THEO = YES HIT/BASIC,NORMAL,15.4514,12.5083,-17.7499,0.9977298,-0.0673444,0,15.4457,12.4704,-17.7224,USE THEO = YES ENDMEAS/ CIR4 =FEAT/CIRCLE,RECT,IN,LEAST_SQR THEO/12.9418,7.5737,-17.6873,0,0,1,0.4465 ACTL/12.9411,7.5735,-17.7381,0,0,1,0.4467 MEAS/CIRCLE,4,WORKPLANE MOVE/CLEARPLANE HIT/BASIC,NORMAL,13.1338,7.6895,-17.6873,-0.8563899,-0.5163297,0,13.1316,7.6922,-17.7381,USE THEO = YES HIT/BASIC,NORMAL,12.7713,7.4277,-17.6873,0.759656,0.6503252,0,12.7479,7.4596,-17.7381,USE THEO = YES HIT/BASIC,NORMAL,13.0433,7.3762,-17.6873,-0.4572583,0.8893339,0,13.0411,7.3751,-17.7381,USE THEO = YES HIT/BASIC,NORMAL,12.794,7.7396,-17.6873,0.6650065,-0.7468376,0,12.8003,7.7452,-17.7381,USE THEO = YES ENDMEAS/ DIM LOC1= TRUE POSITION OF CIRCLE CIR3 UNITS=IN ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH DEV PERPEN CENTERLINE=OFF DISPLAY=DIAMETER AX NOMINAL +TOL -TOL BONUS MEAS DEV DEVANG OUTTOL X 15.6724 15.6699 -0.0025 Y 12.4934 12.4941 0.0007 DF 0.4451 0.0000 0.0000 0.0000 0.4503 0.0052 0.0052 --------> D1 0.4465 0.0000 0.0000 0.4467 CIRCLE CIR4 AT RFS D2 0.4473 0.0000 0.0000 0.4470 CIRCLE CIR2 AT RFS TP MMC 0.0000 0.0000 0.0052 164.8219 0.0052 --------> END OF DIMENSION LOC1 A2 =ALIGNMENT/START,RECALL:STARTUP, LIST= YES ALIGNMENT/LEVEL,ZPLUS,PLN1 ALIGNMENT/TRANS,ZAXIS,PLN1 ALIGNMENT/TRANS,XAXIS,CIR1 ALIGNMENT/TRANS,YAXIS,CIR1 ALIGNMENT/END RECALL/ALIGNMENT,INTERNAL
Then it loks like you recall an alignment but it is not established? That will put zero back up to machine zero. Virtually anything you try to check from there will give you a parameter error.
I would:
Measure PLANE
LEVEL and TRANSLATE to PLANE
Meaure Datum Circle
TRANSLATE X and Y to CIRCLE
Measure Rotation Circle
ROTATE to Rotation Circle
You do not HAVE to do the alignment commands imbedded in the features like this. You can measure all the features you need then do the alignment. But, you must have an alignment set before you try to Define and Measure anything.
HTH,Bill Jarrells
by kv802I am trying to run a program supplied by our customer - running in v3.7 MR3.
The part is approximately a 4"dia x 6" high plastic...-
07-15-2007, 05:16 PM -
by littlejoeI lost my job as a CMM programmer/operator after several years, doors closed back in June. Seems to be the way for many shops here in northern Michigan....
10-31-2007, 12:03 AM -
by rdbowmanI am currently running a manual 765 micro xcel machine with pdcmis ver. 3.2063. My company is looking at buying a new 775 ONE machine. I have around...
03-21-2007, 12:09 PM -
by vhansHi Everyone,
I am a new user to CMM and pc-dmis program and I have a question which I cannot solve on my own.
I am trying to...-
04-19-2008, 12:15 PM -
Friday I wrote a program, ran the first piece and program ran fine. Come in today, the operator said the program would not run. Machine parameter out...
01-09-2017, 02:57 PM -
