Hello again,
Here's more info for the PC DMIS masters out there who might be able to heklp me
Hi,
Not quite, but I am so **** close that it's making me batty!!
First I want to say thank You, so Thank You!
Okay, here's the deal for the masters out there
I do not have a fixture
I have left & right and a fore & aft bore........ which all lie on the same plane, I am manually measuring these 4 bores, then I construct a "baseplane" from their respective Ctr points... I will use this to level my (Z+)..........
I then construct a line using my "aft and fore" Ctr. Pts. this is the longest axis (40 In.) and the one that I will use to align/rotate...(Y+)...............
I use my left and right Ctr Pts. and I construct another line,...........
It is at this intersect point (of the two lines at the "baseplane" (where my XYZ .000 is on the model and the one I need the model to align to
If I could just get the model and my manual alignment to "Synch" then I can run with it
Hello,
I am somewhat new to PC-DMIS, but not new to CMM's I have worked with
MM4, AVAIL, VERISURF, and LK STUDIO, I have been in inspection for over 20 years.
My question I am sure will be basic for most of you, maybe someone can help me,
I have started a "new" program, the probes I need were calibrated previously, I have yhe CAD model aligned to the machine axis, the part is sitting on the table exactl the same way that the model is, so everything is good as far as that goes,
NOW, How do I get my Part Coordinate System in alignment with the model????
i did a manual inspection earlier but it is a complex part and we have many to run, I need to get the model and part aligned so that I can begin inspecting features/entities
PLEASE HELP,
John T.
Hi,
Hello,
PLEASE HELP,
John T.
