I just updated from 3.7 MR2 to 3.7 MR3 and I keep getting an error on the move point after a wrist change. The error is " DOF : M54 invalid machine not in manual mode". Just wondering if anyone else has had the same problem and if the knows a workaround.
Dof : M54
Originally posted by Nevets View PostI just updated from 3.7 MR2 to 3.7 MR3 and I keep getting an error on the move point after a wrist change. The error is " DOF : M54 invalid machine not in manual mode". Just wondering if anyone else has had the same problem and if the knows a workaround.
FIND HOLE
RE-MEAASURE
READ-POS
ON ERROR
If so, and IF it is going to measure a hole NEXT, just put in a dummy vector point, like right next to the hole.sigpic
Originally posted by Nevets View PostNo, I am using auto-circles but I am not using any of the items you listed. It only does it when I have a move point directly after a wrist movement.sigpic
(sorry for the late reply, lunch break)
In the case of the short program I just wrote, the feature it is going to measure after the wrist change and move point is an Auto vector point. I tried adding a false construction point before and after move point and still came up with the error.
I have hundreds of production programs that this error will affect. I have seen it in several programs already.
I have hundreds of production programs that this error will affect. I have seen it in several programs already.sigpic
by Ben YtreeideI am using an 18mm disc to get through a 0.747-in hole to measure CYL_E_IN5. I want to be able to go straight down the hole until I reach the cavity and...
08-03-2016, 03:05 PM -
by AlexAI want to be able to load a part on a fixture either way up, and the program select the correct cycle based on whether a hole is or isn't present....
05-24-2012, 06:11 AM -
by QS920The parts are sheet metal ( motorcycle fenders at the moment) and my experience with sheet metal is non existent for programming. The program is in cad...
10-15-2017, 06:39 PM -
by #2#I just started using 3.7 MR3. I did not notice this problem with MR2. When using the find hole function if the tip starts into the hole and then hits...
05-18-2006, 05:18 PM -
In utilizing "Find hole" Probe approaches hole at movespeed than changes to Touch Speed and feeds a bit (this part looks fine so far) however...
09-04-2007, 12:46 PM -
