If I would like to set up a prgm to check multiple gages automatically at night when I am not there, can it be done? What would it take to configure the CMM to run the first prgm, print out the report then move on to the next gage, print out that report & so on?
multiple gage prgms & reports
by dlewisIs there a way to configure PC-DMIS to setup any 3 gages (indifferent body positions) & run each program & print out a report, move on to the...
08-15-2007, 12:22 PM -
by UnderspecAnyone done any GAGE R & R's with PCDMIS? What was your repeatability? Range?
11-07-2006, 11:43 AM -
by D-TrainI've been asked to do a Gage R&R project using the CMM as the gage, and a step gage as the control subject. We are trying to determine the R&R...
06-05-2017, 10:41 PM -
by calbrittonI have two 2.25 class XXX setting gages. the ID of the Ring gage measures within .000010" of nominal but the Plug gage is measuring minus 000045"...
09-17-2016, 07:36 AM -
by DrEaMcMmhi,
i hav trimek CMM,the problem is that its measuring the 500mm gage block's nominal value as 500.012 and the actual or measured value is 500.022.can...-
12-06-2006, 12:04 PM -
