Anybody notice when you use the group command it hides the first item (with show all params=yes)? The real kicker is until you delete the group command you cannot edit that item. WTF.
Group cmmnd hiding *****
Originally posted by slesholdofthreep View PostAnybody notice when you use the group command it hides the first item (with show all params=yes)? The real kicker is until you delete the group command you cannot edit that item. WTF.sigpic
Code:GRP1 =GROUP/SHOWALLPARAMS = YES MOVE/CLEARPLANE F1 =FEAT/CONTACT/VECTOR POINT,CARTESIAN THEO/<-3.58,120.804,128.787>,<0,0.9999972,-0.002356> ACTL/<-3.575,120.263,128.765>,<0,0.9999972,-0.002356> TARG/<-3.58,120.804,128.787>,<0,0.9999972,-0.002356> SNAP=NO SHOW ADVANCED MEASUREMENT OPTIONS=NO SHOW_CONTACT_PARAMETERS=NO MOVE/CLEARPLANE F2 =FEAT/CONTACT/VECTOR POINT,CARTESIAN THEO/<26.29,120.745,103.766>,<0,0.9999972,-0.002356> ACTL/<26.292,120.301,103.748>,<0,0.9999972,-0.002356> TARG/<26.29,120.745,103.766>,<0,0.9999972,-0.002356> SNAP=NO SHOW ADVANCED MEASUREMENT OPTIONS=NO SHOW_CONTACT_PARAMETERS=NO MOVE/CLEARPLANE F3 =FEAT/CONTACT/VECTOR POINT,CARTESIAN THEO/<-6.176,120.673,73.461>,<0,0.9999972,-0.002356> ACTL/<-6.174,120.366,73.443>,<0,0.9999972,-0.002356> TARG/<-6.176,120.673,73.461>,<0,0.9999972,-0.002356> SNAP=NO SHOW ADVANCED MEASUREMENT OPTIONS=NO SHOW_CONTACT_PARAMETERS=NO MOVE/CLEARPLANE F4 =FEAT/CONTACT/VECTOR POINT,CARTESIAN THEO/<-30.881,120.737,100.484>,<0,0.9999972,-0.002356> ACTL/<-30.875,120.322,100.463>,<0,0.9999972,-0.002356> TARG/<-30.881,120.737,100.484>,<0,0.9999972,-0.002356> SNAP=NO SHOW ADVANCED MEASUREMENT OPTIONS=NO SHOW_CONTACT_PARAMETERS=NO DAT_F =FEAT/PLANE,CARTESIAN,TRIANGLE,NO THEO/<-3.587,120.74,101.624>,<0,0.9999972,-0.002356> ACTL/<-3.583,120.313,101.605>,<0.0002646,0.9999982,0.0018631> CONSTR/PLANE,BF,F1,F2,F3,F4,, OUTLIER_REMOVAL/OFF,3 FILTER/OFF,WAVELENGTH=0 ENDGROUP/
By the way, thanks I learned something new today. I don't know that I will use it but you never know. Again thanks.sigpic
Originally posted by slesholdofthreep View PostI'm sure you're right about 4.2. I just have a lot of other things to check off my to do list at work before i can move on that.
Off topic
James are your coord for real? You anywhere near the place where the Riel Rebellion took place? I've got First Nation bloodlines from there.
Off Off topic(hijack?)
What does "slesholdofthreep" mean.sigpic
Originally posted by slesholdofthreep View PostLate one night I decided to announce my state of being prior to going to bed. I meant to say "I'm on the threshold of sleep". Spun with foonerisms.sigpic
James, your coord's are good google maps ain't. I used to live in a small podunk town south of Grand Rapids MI. Man I miss the great lakes. Tell me is the weather just as muggy in Wisconsin in the summer as it is in MI? Always wondered if being on the west side of the lakes might be a little drier.
Originally posted by slesholdofthreep View PostJames, your coord's are good google maps ain't. I used to live in a small podunk town south of Grand Rapids MI. Man I miss the great lakes. Tell me is the weather just as muggy in Wisconsin in the summer as it is in MI? Always wondered if being on the west side of the lakes might be a little drier.sigpic
CYber stalkers
Originally posted by slesholdofthreep View PostHaha CuMofo supreme master of cyber stalking you are. Something to do with 8th generation honda civics and mountainbiking it does. Perhaps pertaining to Road Kings in future it will.
hmmm.
Yoda talk like you do.
http://www.starwars-tw.com/story/cha.../jedi/yoda.jpg
Hold of three peas Less you have.
See Les Hold of Three Peas
http://www.heirloomstocherish.com/in...%20a%20Pod.jpg
GLast edited by Cumofo; 08-04-2007, 11:37 AM.sigpic
by boximusI have a program that checks a part the same way 3 times, then reports out the true position of a single hole (3 times). When I look at the reports I...
11-09-2007, 05:36 PM -
by David WedelMy model has three target pnts that are off the cad surface. what i am wanting to do is drive my 3 pnts normal to the points on the surface and offset...
03-20-2015, 02:28 PM -
by John KuglerAnyone else having an angularity issue?? I'm just trying to do the angularity of a line. I am having a TON of issues with this. When I run my program,...
03-17-2008, 11:50 AM -
by 35DodgeNeed a little ( okay a lot) of help. Working on the part and because of how the part was drawn in Solid Works I am unable to use Auto Features. Production...
02-07-2017, 07:47 PM -
by tjackson2Using an ABC aligment (plane, line, plane) my coordinates are way off position. For example, I have a 13.5mm diameter at 153, 567.5, 0. theoreticals are...
05-15-2012, 02:54 PM -
