Measure a cone angle
  • Measure a cone angle
    I am fairly new to PC DIMIS and am trying to measure a cone angle. The version we are using is 3.7. I go to location and pick the cone and select A. This gives me the included angle whereas I only what the one side angle of the cone. Help if you can.
    thnx
    Follow this link to a method I have posted before.
      Unfortunatly still a little clueless here. I am only to the point of measuring features and dimensioning. Can you walk me through creating the needed info.?
        I replied to your PM. I was doing that from memory, I'm about to leave for the day and my CMM is shutdown.
          Type AS then tab over.
          ASSIGNMENT/V1=0 will appear
          Dbl click on 0 and type in your feature name.ANGLE/2
          i.e. ASSIGNMENT/V1=CONE.ANGLE/2
          Type GEN then tab over
          F1=GENERIC/POINT will appear
          Dbl click on POINT and type in NONE
          Go down to ANGLE
          The first toggle field is for your nominal, enter it here
          The second toggle field is the measured angle, enter your variable name here i.e. V1
          Now simply Dim>Location>A>F1
          Good luck!
          sigpic 1.61803399Δ
            The above method is correct, but I do believe that the assignment should read,
            You can also use the keyin dimension and type in your variable name (V1) in the actual box. Never tried it with an angle though.
            Goto
            INSERT
            DIMENSION
            KEYIN
              You are correct Darin. Long day yesterday. If there are any questions on a variables syntax, place the cursor on the assignment and hit F2. This will bring up the expression builder.
              sigpic 1.61803399Δ
              • B. Jacobs
                Cone Angle
                by B. Jacobs
                I have measured a cone and now I want to find out what the angle is. How would I measure this. I tried Angle between but keep getting 90deg. What am I...
                03-23-2006, 04:22 PM
              • J. Lusk
                cone angle
                by J. Lusk
                How would you measure the angle of the face of a cone in relation to an adjacent plane? I'm getting a close but no cigar (48 deg. -vs- 50 deg.) When I...
                08-19-2008, 05:13 PM
              • Curty_82
                cone angle
                by Curty_82
                ok so i programmed this cone to check the angle but it doesnt repeat anyone know why?
                08-26-2008, 04:18 PM
              • JLHUTT
                Checking angles on a cone
                by JLHUTT
                I am new to the programing, first week, so this question my sound pretty basic. When I am checking an angle on a cone, I measure the cone feature and...
                10-12-2007, 08:14 AM
              • Nasejhmoob
                Dimensioning Cone angle
                by Nasejhmoob
                How do I dimension Cone angle? Can I dimension a 10° angle straight from an auto cone without having to make a line? Thanks
                07-08-2016, 04:42 AM
