form and location
  • form and location
    Let me confuse everyone. I have a cube and a radius (B) on top of the cube. Datum A is a vertical plane on the cube. The print calls out for form and location .004" from B to A. I level to Datum A as part of my iterative alignment. I measure rad B as a scan. What would be the correct method to dimension this feature. If I use form and location does PC-Dmis use x,y and z in the calculation. The function of Datum A is to locate the part in x and I know I will be asked to take the z error out of the calculation.
    To the Brave and the Faithful nothing is impossible
    Do you have a print or sketch we could see?
      Well, that scan WILL have to have cad nominals (ie generated from cad data) or you will not be able to ro form or form & location on it. However, if I understand you correctly, the peak/high-point/top of the radius is the locator, not the radius itself. If so, measuring the radius will NOT get you the correct B datum, you need a SINGLE high point from it. Not that this gets the answer, but......
