By holding both of these, u should be able to draw a box around your features and zoom in. It's not working for me. This happened awhile back and it just started working again. When you do it, all it does is pan. Any ideas?
L & R Click
Tags: None
Originally posted by Wes Cisco View PostAre you sure your mouse if fully functional? It could be a cheap import from China. Try plugging in a different mouse. Also, for good measure, check your Scroll Lock Key.
09-26-2007, 03:00 PM -
by bharpoldTry this. If you right click by your toolbar, if should have toolbars listed and at the bottom should be customize. After you right click look and see...
01-18-2009, 09:05 AM -
by TigerSharkI have an issue with partial execute, it always was working, I am not sure what happened that is not working now.
CTRL+U that is the execute...-
12-03-2009, 05:40 PM -
by mprice1984We just loaded 2014.1 onto a new CMM. Most everything is working well but I am unable to use the Ctrl+E or Ctrl+U functions while running a program. I...
05-01-2015, 01:17 PM -
