Non-sphere probes.
Gday,
I believe you would just select whichever you are using ( disc or cylinder ) when you build up your probe in the probe utilities box, the software should compensate for this. ( just put your cursor next to the probe in your program and hit F9 ). cheers.
The Cougar
If you don't have a profile for your cylinder/disk probe already in your 'tip library', then you'll have to teach it by qualifying under the 'manual DCC' button on your probe qualification window. Once you have it in your library, it will qualify just like any other probe.
Don't forget to add the additional hits for the "Shank Qual" if you are using a shaft or cylindrical probe.
http://i76.photobucket.com/albums/j2.../untitled2.jpgsigpic
PCDMIS 2012
Windows Office XP
by Clay_ManHi All
I am looking for a little feedback (HELP) on how to measure the spline I.D. datum B and the other feature, was thinking of using...-
03-31-2006, 04:49 PM -
by EBUSHI have been trying to use my ruby disc probe but i can not get any of the dia. or runouts to come out correctly. I calibrated it manually like it says...
11-11-2009, 12:07 PM -
by UseAsIs***Solved: The probe file that Hexagon sent me had a serious error - The disk diameter was set to "0," so the machine tried to drive straight...
04-19-2019, 11:14 AM -
by ClayOgreI have a V-8 Engine block that I need to get down inside and measure the bottom of the liner bores on, there is something of an undercut on the head deck...
01-15-2008, 03:08 PM -
by GScottBI'm trying to calibrate a disk probe that was in the library. The only difference is every disk probe in the library doesn't have the two little nibs...
02-08-2012, 07:58 PM -
