Probe Depth
  • Probe Depth
    I set the Probe depth at the beginning of the program I'm writing, but I can't find it now, and I note that I'd like to have the probe NOT enter the hole as deeply as it is, for the 500 holes in my plate that I have.
    Where do I look to find the probe depth setting?
    Where should the probe depth be, in the program, to do the same on all the holes?
    How do I reset the probe depth as the default for this particular program, (all holes?)
    -Soupy1957
    sigpic"I used to know what I was doing, but that was before I forgot!"
    -Soupy1957
    PC-DMIS 4.2/4.3MR 1
    Tutor
    -Soupy1957
    I'm not sure what you mean but...
    Do you know part of the probe depth command? You can do an edit-find and search for text. That might lead you to where the command is located.
      Are you talking about move points, are you measuring auto circles, not sure what you mean ???
        I've got a plate that is .125 thick
        The holes in the plate need to be measured for X,Y and Ø
        I don't want the probe to go too deep in the holes
        The probe I'm using, has a 2mm Stylus
        How do I set the amount that the stylus goes into the hole on Z-?
        -Soupy1957
        -Soupy1957
        PC-DMIS 4.2/4.3MR 1
        Tutor
          Are you doing auto circles or manually taking the hits. If your using auto circles you can set your depth with sample hits & depth if they are manual then set your z orgin to the depth
            The depth should be set by you for each feature. You can use a variable if you want each feature to be the same and you think it is something you might need to tweek. Be mindful of alignments though.
              Also, are you using findhole? If so maybe you are talking about how far into the hole it searches. In that case, the search distance in the F10 menu - motion tab is what does it.
                -Soupy1957
                AUTO
                Probe Depth is set in the Auto Measure Command
                Measure Mode
                Probe depth is set by the location of the points you take.
                Bill Jarrells
                  I did not use "Auto Circle" (Purple Icon) for locating the holes. The holes were identified by mouse clicks on the CAD Model first, then I ran the program.
                  I'd like to decrease the depth that it defaults to taking for all holes. the "F10" menu settings for "depth" only pertain to holes measured by "Auto Circle" (the Purple Icon) correct?
                  -Soupy1957
                  -Soupy1957
                  PC-DMIS 4.2/4.3MR 1
                  Tutor
                    -Soupy1957
                    Somebody correct me if I am wrong but PC DMIS invokes Auto Circle when you pick from CAD, right? It has been a while since I grabbed a circle in CAD.
                    I think if the circles are already writtin you will need to modify them individually. Do an F9 on the measure command and it will either be Auto or Regular Meas. Either way you can fix it there. If there is a global, retroactive fix??
                    Bill Jarrells
                      If you hit the program mode icon and take hits with mouse clicks it is not in auto circle mode it is in learn mode. I am not sure if this is what you meant by the above stated. Really not grabing the circle but measuring from cad. Soupy -IF the circ was measured in learn or teach mode look at the code and change the z Can be done in theo or by the actual hits.
                        Ok, I'm going to ask why you want to change the depth.
                        Why do you want to change the depth?
                        Changing the depth on 500 holes one at a time (if it turns out that is what you will have to do) is going to be a very long, annoying job.
                        Will the hits fall in the correct place on the holes? Is the problem that the probe will stick out past bottom of the hole and 'crash' into whatever is underneath?
                        If that is the problem, can you just elevate the part somehow so that it is open underneath the part?
                          Right, in hits mode. But can't you grab the circle as a feature and leave hit mode out of it?
                          Bill Jarrells
                            All 500 holes are "thru" and the plate thickness is constant, (.l25) therefore, I'd be more than happy to do a "blanket" depth, if possible.
                            the probe tends to default to a little lower than I feel comfortable with.
                            I'll take a look at the suggested locations in F10 and see if that helps...thanks.
                            On to the NEXT issue....lol. (I start prepping the report settings tomorrow).
                            -Soupy1957
                            -Soupy1957
                            PC-DMIS 4.2/4.3MR 1
                            Tutor
                              -Soupy1957
                              Can you post some code with reference to the circle(s) you want to change? One or two would be fine.
