Tolerancing a feature for true position and I'd like to know which is the better method to use. I use 2 studs in the alignment and have toleranced a cast diameter for one of the studs. Is it better tolerance the actual feature after the alignment or tolerance a cast diameter of that stud?
Other software that I have used you would have to recall that feature but I have seen that I do not have to do that in PC-DMIS. You get the same results but am wondering if it'll bite me in butt later.
