I'm trying to construct a plane perpendicular to another plane, I'm hoping someone can tell if there is and easy way to construct the plane with the contructed features area?
Constructing a Feature?
I do the following. Maybe there is an easier way but I don't know off the top of my head. First, does the plane need to be in any particular location?
I'd align to the measured plane (level, set whatever as orgin). Next, I'd create three offset points and just make up some numbers for the offsets. So if the plane is leveled to z-plus and you want your constructed plane's vector to be y-plus I'd create points at -3,0,0; 3,0,0; 0,0,3. Then, I'd construct a plane from those three points.
The bad part is that I'm working in body position & the plane need to relate back to another plane. The purpose of the plane is to measure some features to it. Heres a better idea of what I'm working with. I have a bolt pattern that is made by making a center line between the B & C datum then rotated 15degrees. The bolts are deminsioned parallel to that plane 25.5mm the other dimension is then shown to take that rotated center line & rotate it 90 degrees & dimensioned 43.7mm. So I need the construct plane to be depend on the original center line between the B & C datums.
Originally posted by ptedrum View PostThe bad part is that I'm working in body position & the plane need to relate back to another plane. The purpose of the plane is to measure some features to it. Heres a better idea of what I'm working with. I have a bolt pattern that is made by making a center line between the B & C datum then rotated 15degrees. The bolts are deminsioned parallel to that plane 25.5mm the other dimension is then shown to take that rotated center line & rotate it 90 degrees & dimensioned 43.7mm. So I need the construct plane to be depend on the original center line between the B & C datums.Bill Jarrells
Assign values from the feature(s) that you want the plane relative to and construct your generic plane using those values. That should put your plane where you need it.Xcel & MicroVal Pfx & Global 37mr4 thru 2012mr1sp3
Contura Calypso 5.4
by mrnonameHi,
I was wondering if anyone could tell me how PC-DMIS views a plane to plane dimension. What my boss would like to know is when you level and...-
10-24-2008, 01:14 PM -
Currently am running PC-DMIS CAD++ 2016.0. I have probed a plane but would like to construct a plane based on the high points; as if it was sitting on...
03-19-2019, 10:32 PM -
by AndersII have a group of points (a plane for example) and I want to project them all to a plane (simplest case == WORKPLANE). Is there some smart way to do it...
03-23-2018, 11:28 AM -
by NMC_CMMI hope this is a pretty basic question and I'm just missing something very obvious.
I want to construct a plane parallel to the plane that...-
07-31-2008, 09:51 AM -
by SAmericaI'm measuring a block that should be ground almost true. I took one plane on one area of the ground surface (We'll call this plane A). Then I measured...
10-16-2013, 09:01 PM -
