Typically how does one go about doing a flatness check of a surface with PC DMIS?
Flatness Check?
First, understand that checking flatness with a CMM is not the best way to check flatness. In reality, you will only be checking the flatness of the portions that the probe touches.
Second, take a bunch of manual hits to create a plane or create an autoplane. Then, go to insert - dimension - flatness, select your plane and then click on "create". That should do it.
Originally posted by Goodluck View PostFirst, understand that checking flatness with a CMM is not the best way to check flatness. In reality, you will only be checking the flatness of the portions that the probe touches.
Scans would be best for checking tight tolerance flatness. Just remember to filter your scans if your surface is not perfect.I used to be high on life but I built up a tolerance.
How big is the part. Can it be check on a Plate? I think one of the big misconceptions is the CMM should be used to check everytying on a print. When it if fact there are a lot of reasons to still use the Plate. Problem is the new generations of Layout Inspectors have never been trained to use the Plate and have been thrown onto the CMM and thats the only tool they know. Flatness and Perp callouts are best done on the plate if posible.sigpicSummer Time. Gotta Love it!
I agree with all here. I have often stated, "double check on a plate, verify that your CMM measurements are close." Paul says it well. The technology is hurting in some ways. Fortunately, I have a "kid" (I think he is late 20's maybe 30) checking parts on the plate here. Doing it very well.When in doubt, post code. A second set of eyes might see something you missed.
Originally posted by John Kingston View PostI agree with all here. I have often stated, "double check on a plate, verify that your CMM measurements are close." Paul says it well. The technology is hurting in some ways. Fortunately, I have a "kid" (I think he is late 20's maybe 30) checking parts on the plate here. Doing it very well.sigpicSummer Time. Gotta Love it!
Originally posted by Paul Sarrach View PostHow big is the part. Can it be check on a Plate? I think one of the big misconceptions is the CMM should be used to check everytying on a print. When it if fact there are a lot of reasons to still use the Plate. Problem is the new generations of Layout Inspectors have never been trained to use the Plate and have been thrown onto the CMM and thats the only tool they know. Flatness and Perp callouts are best done on the plate if posible.sigpic
by gsepanGood Morning all,
My question is regarding a flatness callout on a print I'm working to. The callout wants to hold a flatness of 1.5mm...-
08-28-2006, 10:47 AM -
by Don-ARIHow accurate is a flatness measurement taken on a surface that I had to level to?
With what I have available using open setup, I am really measuring...-
09-10-2010, 12:10 PM -
by grandpaal56I have a part with a surface that is about 800mm long by 200mm wide the print is calling for a flatness overall on the surface of .05mm, and a zonal flatness...
03-08-2011, 09:22 AM -
by bjpenningsDoes it matter what order you take points to measure flatness? Should the first 3 or 4 poit be taken spread out over the entire surface? Maybe this is...
10-15-2009, 03:14 PM -
by kuulpinoyWhen flatness is called out on drawing. How many hits and how far away are each hit has to be? What is the proper way to manually very a flatness call...
Channel: Tips & Tricks
07-21-2014, 10:15 PM -
