is there anyway that i can remove the dev angle callout from the tp report thx
removin deviaton angle from tp callout??
I have a part with 5 holes drilled into the circumference of the part. All are in line in Z, but are 10 degrees apart from each other in polar angle....
08-09-2006, 12:14 PM -
by jure1992Hello all.
I have one problem with reporting TP which have for nominal an angle and distance.
is this even possible in PC-DMIS?...-
05-24-2016, 03:09 PM -
by NikoMHello to everybody.
Use to run into that issue before, but I would ask you to remind me what I should be aware if I want to report TP for...-
05-15-2006, 03:13 PM -
by PowerJunkieYES!
Ok, CMM's don't exist and I need to check the TP to the attached example by means of indicator and v-blocks, that's it. I get a single...-
02-24-2010, 11:38 AM -
by MJBolsterI have a cylinder like a hub of a wheel with spokes coming out all around at 30 degree intervals- like a wagon wheel- easy to visualize I hope. Okay-...
08-30-2007, 05:40 PM -
