Yea, that's right. When you dimenion true position right before an alignment and you go and change the tolerance on it then "TAB" down, everything changes. I think it changes it to the alignment below.
True Position Wacked
Originally posted by craiger_ny View PostYou say "everything changes", could you elaborate?
No I can't try it. I don't have 4.1.
The X, Y, Z measured values change.
I usually tab around dimensioning in the command window to change tolerances or nominals and have noticed this since using v4.1.I used to be high on life but I built up a tolerance.
Are you saying the reported values are wrong?Bill Jarrells
Originally posted by Wingman View PostAre you saying the measured values change in Aligment ABC if the next command After your TP Command is DEF (or anything to that effect).
I'm saying if you have an alignment of any kind right below your TP dimension and you "TAB" from the TP dimensioning to the alignment, the measured values change in that dimensioning.I used to be high on life but I built up a tolerance.
Originally posted by Underspec View PostI'm saying if you have an alignment of any kind right below your TP dimension and you "TAB" from the TP dimensioning to the alignment, the measured values change in that dimensioning.
I've not seen that before....That's wacked.......sorrysigpic.....Its called golf because all the other 4 letter words were taken
Originally posted by Underspec View PostI'm saying if you have an alignment of any kind right below your TP dimension and you "TAB" from the TP dimensioning to the alignment, the measured values change in that dimensioning.Bill Jarrells
Originally posted by Wingman View PostI have always thought PC DMIS thinks it is too smart. I would like to turn all that auto update crap off and leave what I type alone.
by AmberWhy is my true position listing my X and Y different than what the actual locations say they are?...
10-21-2014, 09:41 AM -
by GuestCan anyone tell me what the formula is for True Position? For whatever reason this engineer thinks that the true position should have a bilateral tolerance....
06-12-2008, 07:22 PM -
by Ken8282I recently did a true position and may 321 alignment to the datums and picked the feature to be true positioned but I get a smaller TP than if I do a...
04-30-2018, 03:38 PM -
by j.gonzalezso i have a sketch of what im doing i need to find true position in x direction from my datum(1.849 dia) need help keeps giving bad numbers checking manually...
06-04-2009, 07:43 PM -
