I wrote the following problem I am having a few days ago and was not able to get back with the requested information. I have attached the manual and CDD alginments. I am using 4.2 version.
I wrote a program for a flat round disc with a center hole. I used two standoffs with threaded holes for alinement then moved the origin to the center hole of the blank. The first 6 blanks ran find then the cmm had trouble finding the first hole on the alinement. It would stop just short of surface when checking the plane or it would crash into the surface. I hit PF9 and redid the hits on the hole and ran test they worked ok. Program asked if I wanted to change the alinement with the data from the test, I hit ok. The program ran ok for two blanks then it did it again. When it crashed into the surface when doing the plane checks I raised the probe back up then it took off in another directions and hit the table. The next time this happened I grabbed the job box and tried to run the probe up as it ran along the table. If I let it go it would go down and crash. Can anyone tell me what is going on and how to stop it? I shut the system down several times and restarted. It did the same thing after running the first blank ok. The last time I tried this it crashed on the second hole during the alginment.
