We are having some discussions here regarding tolerance blocks and the correct usage of them. We have our "standard" tolerance block. Any dimensions that require a different tolerance are shown with a tolerance on the print. When we receive a customer print with a tolerance block different than ours, a note is added to the drawing that shows the customers tolerance block. Here is the problem, no flag is placed near the tolerance block on our print. I've seen a number of manufacturing personnel stop looking once they see the "standard" tolerance block. I feel this is poor practice by Engineering/Drafting. I'd like to hear everyone else's thoughts.
Tolerance Blocks on drawings
I don't think you should have 2 tol. blks on a single drawing. Personal pref.
I'm not sure, but I think the line convention group (asme) might have a standard for that, but don't quote me.
It would seem you would want a simpler drawing, not a more complicated one. Why can't you omit yours when the customers goes on, and visa versa??
i wouldn't like that.
What about crossing (X) one out???
I've seen JIS and DIN and ISO and ASME done this way...
KevRFS Means Really Fussy Stuff
I feel that if there is a deviation to the general tolerance, then it nefinately needs a flag or a note. All personel involved needs to be able to read a print and that includes paying attention to the details of the print.
A.GoresigpicA.Gore
I see where that could get confusing. I see where some may take advantage and go with the biggest tolerance or that conforms with there need. I personlly would not have two blocks. But in the end I would have to say whose is the end user, and use there block.sigpicSummer Time. Gotta Love it!
I'm guessing at an answer to Tom's question because I'm working on PPAP's at this time with prints in which our customr has pasted their customer's prints onto their own title blocks.
In this case I only have 1 tol block but can easily see a scenario that would have 2 tol blocks. If I were to see prints with 2 tol blocks I would not accept them from our eEng Dept until one of them was removed or crossed out.Perry
B&S Mistral
3.207 Beta on XP
Older'n dirt
We create our own drawing. So it isn't really 2 tolerance blocks, but our tolerance block, and then a note with tolerances in it.
IE Note 5. Tolerances UOS
.XXX +/-.010
.XX +/-.030
So which UOS applies? It can put you in a loop, cause the drawing tol block also says UOS.When in doubt, post code. A second set of eyes might see something you missed.
Originally posted by rebeldudeI would guess any dimensioned areas marked with a 5 will have those particular tolerances you are showing us applied, and any not marked with a 5 would default to the other tolerance block. Thats how I would personally read itWhen in doubt, post code. A second set of eyes might see something you missed.
John,
It seems to me that I spend all day long ticking people off! But if nothing is flagged, then so be it right? Unless the print is updated, or if they sign something stating otherwise, then you got to go by what imformation is handed to you.Last edited by rebeldude; 04-21-2006, 08:33 AM.sigpic
I'm in the same boat. Tick 30 people off by doing the job right. Tick off my boss, his boss and myself by bending to their whims. In the end I report to the QC Manager, President of the company, Customers, and Myself. QC is a thankless job at times, but I love and live it.When in doubt, post code. A second set of eyes might see something you missed.
Yeah, it's nice to be able to sleep good at night knowing you did your best...And not having to sit there in a pool of sweat with a 40 ounce and a loaded shotgun - hoping to pass out...
by JigneshThe True position of hole is not given in the piece. The report window showed x and y coordinate values with measured value of diameter. Tolerance +\-0.1...
04-27-2022, 07:39 AM -
by April11996
OK - not an April's fool.
Was just sent a print with the attached TP for an M10 threaded hole. I've not seen...-
04-01-2015, 07:38 AM -
I have been with this latest company for just over a year. I have yet to see an "S" preceding Ø on a Position FCF. Many of the features that...
06-05-2019, 07:39 AM -
by Sl33stakLets say I have a hole true positioned on a print to say, .5mm. Also on the print I have the X and Y coordinates BOXED.
Now lets say that...-
12-11-2008, 12:44 PM -
by YGOLORTEMIt's been a while since I've had to do this in PC-DMIS so please bear with me.
I have a Ø 0.250 with a +0.001 / + 0.001 tolerance. Is there...-
07-20-2020, 07:23 AM -
