Going to be using a .5 mill probe will paremeters on motion for touch speed need to be set down. I have never used one that small. thanks for any help
.5 probe
I have mine at 1%. I think the biggest problem you would have is if there is a manual point staight down and someone hits too hard. I've had inspectors say it just fell off. But suspect abuse when taking manual points and not the program. I usually slow it down if I don't have much clearance just to make sure and speed up where I can but leave it at 1%.
I do this every week. I have a groove that is .03" and use a .5 (.02"), .005" per side clearance. I usually run my programs at 75% machine speed and 100% on the jog box w/ 1.5 touchspeed. With the .5 probe I use 25% machine speed and 50% on the jog box w/ 1.0 touchspeed. I ran a lot of test to see what kind of accuracy I was getting and this was what I ended up w/. It is well w/in .0001" of accuracy on my parts. I can measure them manually w/ an indicator, just takes a lot of time so I use the machine to save time.Dale
v2011 MR1 CAD ++
Originally posted by kass_b View PostI beilieve that well time to go home. just wondering if i turn touch down less likly to break?Bill Jarrells
Same we use 0.5 probes a fair bit , usually rapid to and from tool changer at high move speed 80/100 % but drop move speed to 20% and touch speed 1% whilst probing. Havent broke one yet touch wood.. 2c
The Cougar
by 1CMM4MEYea, I know it's somewhere in the threads, but I have looked for an hour and have not found what people generally run their machines at and their touch...
09-09-2008, 09:24 PM -
by JoeMarsdenIs it necessary for the touch speed in the part measurement be the same as the touch speed in the probe calibration?
09-30-2013, 08:40 PM -
by BlaestHow would I change the probe change speed - I assume it is done on the machine and not in the program, but I might be wrong?
I have looked...-
04-23-2014, 05:11 AM -
by MikeFI was told by Hexagon support to use 2mm per second touch speed but when the tech was here to calibrate my machine he was using 5mm per sec. what do you...
06-13-2019, 09:25 AM -
by NguyenI've read the "Styli .5mm.." thread and everybody (maybe almost) suggests to have a slow touch speed. Is it because of the concern of bending...
01-20-2009, 11:41 AM -
