Iterative Alignment Problems
  • Iterative Alignment Problems
    Hi All
    I am trying to align a fixture, using iterative alignment. I have done this 100's of times with no problems. This time, however, I am having trouble. When I am finished with the alignment, it is WAY off. pretty good in the Y axis, but about 100 mm low in the Z axis, and about 100 mm forward in the X axis. I have double checked my probe build, it is correct. Any other suggestions?
    Try posting your alignment here and let us take a look at it.
    Starrett RGDC 4028-24 :alien:
      check tooling ball noms
      tb's may also have been labled with wrong noms
      change some numbers that may work & try best fit
      see if it starts to get better
        A0 =ALIGNMENT/START,RECALL:STARTUP, LIST= YES
        ALIGNMENT/ITERATE
        PNT TARGET RAD = 5, START LABEL = , FIXTURE TOL = 0, ERROR LABEL =
        MEAS ALL FEAT = ALWAYS ,MAX ITERATIONS = 99 ,LEVEL AXIS=ZAXIS ,ROTATE AXIS=XAXIS ,ORIGIN AXIS=YAXIS
        LEVEL = SPH1,SPH2,SPH3,,
        ROTATE = SPH2,SPH1,,
        ORIGIN = SPH2,,
        ALIGNMENT/END
        I have double checked all of the above. The fixture/TB/alignment has worked fine as I said about 100 other times. I don't get it...
          what are the nominals for the tooling balls
          could it be missing a negative number or vise versa
          do you have scribe lines on the gage
          are the distances correct from edge or scribe line
          use calipers for rough reading
            I checked all this and more. I just ended up mirroring the part program, and using an existing alignment, all is well. PCDMIS glitch, I guess It is exactly the same in every way as the one I was trying to use. I don't know...
              Worse comes to worse, in the future. And it will. Start over. I have done that with success before.
                pc demons - be gone
                  did you shut down and reboot
                  that works sometimes
                    You can also do a manual long way alignment just to verify,Where youcan first Measure a feature then level then measure the features(feature) for your rotation then rotate then crate the Origen,just another way to verify your previous alingment.
                      reply
                      Try to have sphere # 3 as origin , or ask fixture builder if the have the z plane , as -z , z plane direction is from up to down
