4.2 loadprobe
  • 4.2 loadprobe
    has anyone else noticed that the loadprobe command does not always stop the program for you to change probes?
    seems to not "see" the command and then crashes because wrong probe is still attached to TP200
    if I put a comment line just before the loadprobe command it works just fine
    Starrett RGDC 4028-24 :alien:
    Another reason to not upgrade......That would stink
      Try a readpoint. That way it doesn't stop for the comment.
      It does it in 3.7mr3 occasionally too.
        I had the same problem but when I used loop command ; loadprobe command were out of the looping. Copied loadprobbe command inside the looping.
        Either seem as you are or be as you seem.M.J.Rumi
