Run time error
Just shootin in the wind, whens the last itme you did a defrag on your computer? For that matter, if you are and I ssume so, if you can read this, do you have spyware remover software? Have you ran it? Spyware will eat up your memory. It runs all the time.sigpic
to add to Rebel, have you ever used " Windows cleanup" ? I have to do it all the time. Here is the web site, and its free. We swear by it at my work http://www.stevengould.org/software/cleanup/ I have fought that "run time error for years, I no longer have that problem.
CleanUp! 4.5.1
Supports
Internet Explorer,
Netscape,
Mozilla,
Firefox
and Opera.
Runs on
Windows 95
through
Windows XP.
Support
CleanUp!
Make a donation
today - click
below
Free disk space, make your computer run better/faster and protect your privacy - all in one easy solution. All for free!
Introducing Windows CleanUp!, the quickest and easiest way to delete temporary files from your system.
CleanUp! is a powerful and easy-to-use application that removes temporary files created while surfing the web, empties the Recycle Bin, deletes files from your temporary folders and more.
CleanUp! frees disk space and reduces the "clutter" on your computer helping it to run more efficiently. It also can be used as a way to protect your privacy on the Internet. You can even instruct CleanUp! to securely delete files making it impossible to retrieve their contents using lower-level disk tools - just another way of protecting your privacy.
No gimmicks here, CleanUp! is so easy to set up and use that you'll have a lean, clean, mean machine in minutes.
Thanks for trying CleanUp!
Steven R. Gould
- Author of Windows CleanUpsigpicSummer Time. Gotta Love it!
Try lowering your video resolution and to 16bit if not already. We still have random PCDLRN shutdowns at the moment. They happen every now and then. It is probably a PCDMIS bug. We are still using MR1 though.I used to be high on life but I built up a tolerance.
I try to give pcdmis as much of the system resources as possible. I am running XP with the Performance Settings set to "Adjust for best performance". Right click, MyComputer, Properties, Advanced Tab, select Performance Settings. It is not as pretty as the other selections but it does not contain the MS toolbar resource leak issue.
by rolsartomI need to upgrade my computer, question is, will 3.7mr3 run on Windows 7 and/or Windows 8.1?
05-29-2014, 12:46 PM -
by philwellDoes any one know if Pc-dmis will run on windows 7
08-21-2009, 07:21 PM -
by baylorbearDoes anyone run Windows XP with PCDMIS? We are changing over from Windows 2000 here. Does anyone have problems or does it matter? Thanks and have a PCDMIS...
06-14-2006, 09:46 AM -
by DarrollhGood evening,
Will PC-D work well on Apple computers?-
09-11-2018, 12:57 AM -
by jaymundayJust baought a machine cheap with version 3.08. My problem is the CPU doesnt have USB ports. I need USB to get my cad files downloaded. The step files...
05-15-2012, 02:58 PM -
