V4.1 Reporting
  • V4.1 Reporting
    Gday all,
    How am i able to make my report window show "errors only" i was able to do this in my old version but cant seen to find it in this version. It was the same sort of box which comes up when you go edit window layout but for the report window. cheers
    The Cougar
    Right-click on any text that isn't inside of a table or in the white space at the end of the Report window and select Edit. That should give you the option to show just the out-of-tolerance dimensions.
      Thanks problem solved so easy when you know how. cheers
