I'm measuring cylinder type parts with ID's and OD's then spitting out concentricity. My issue is that even after taking a plane and origin hits, my concentricity is way high. Roundness on the dimensions are around .0005. The part must be tilting a bit on the fixture. How can I compensate this tilt even after taking a plane to get an accurate concentricity dimension???
Thanks
Thanks
