Hi,
I've been working with reading a file with multiple points and running them using a while, end/while loop. Got that to work. Now I'm trying to write the data (measured values) to a file such that it comes out in a row of X, Y, Z, T. I've got the commands exactly, as far as I can tell, like they are in the help? files. It runs but does not put anything in the text file. Below is what I've got. Can anyone tell me where I'm going wrong? This is starting to get frustrating.
Thanks for your help.
ASSIGN/P = 0
FPTR =FILE/OPEN,C:\PCDMISW_37\DATA\TKRDLTEST.CSV,READ
MOVE/POINT,NORMAL,859.827,1866.5452,890.2236
COMMENT/REPT,SCAN POINTS TEST
WHILE/P<5
ASSIGN/P = P+1
V1 =FILE/READLINE,FPTR,{X}+","+{Y}+","+{Z}+","+{I}+","+{J}+ ","+{K}
ASSIGN/QX = X
ASSIGN/QY = Y
ASSIGN/QZ = Z
ASSIGN/QI = I
ASSIGN/QJ = J
ASSIGN/QK = K
P =AUTO/SURFACE POINT,SHOWALLPARAMS = YES
THEO/QX,QY,QZ,QI,QJ,QK
ACTL/771.3183,1945.361,749.7687,0.955064,0.015001,0.296 0198
TARG/QX,QY,QZ,QI,QJ,QK
THEO_THICKNESS = 0,RECT,SNAP = NO,$
AUTO MOVE = BOTH,DISTANCE = 10,RMEAS = None,None,None,$
INIT = 0,PERM = 0,SPACER = 0
DIM PTDIM= LOCATION OF POINT P UNITS=MM ,$
GRAPH=ON TEXT=OFF MULT=100.00 OUTPUT=BOTH
AX NOMINAL MEAS +TOL -TOL DEV OUTTOL
X QX 771.3183 2.0000 -2.0000 -0.5835 0.0000 ---#-----
Y QY 1945.3610 2.0000 -2.0000 0.0273 0.0000 ----#----
Z QZ 749.7687 2.0000 -2.0000 -0.2313 0.0000 ---#-----
T 0.0000 -0.6253 2.0000 -2.0000 -0.6253 0.0000 ---#-----
END OF DIMENSION PTDIM
FPTR2 =FILE/OPEN,C:\PCDMISW_37\DATA\TKRDLTEST1.TXT,APPEND
ASSIGN/ALLVALS = (PTDIM.X.MEAS)+","+(PTDIM.Y.MEAS)+","+(PTDIM.Z.MEA S)+","+(PTDIM.T.MEAS)
FILE/WRITELINE,FPTR2,ALLVALS
FILE/CLOSE,FPTR2
END_WHILE/
ASSIGN/P = 0
WHILE/P<5
ASSIGN/P = P+1
ASSIGN/QX = X
ASSIGN/QY = Y
ASSIGN/QZ = Z
ASSIGN/QI = I
ASSIGN/QJ = J
ASSIGN/QK = K
FILE/CLOSE,FPTR2
END_WHILE/
