I have a hole thru a wall. The axis is not square or parallel to X,Y, or Z and the is no probe tip angle that follows the hole axis either. I must check it as a cylinder, True position in all 3 Planes A,B,& C.
What I must do for probe tip access is check both ends as individual diameters with different tip angles, construct a cylinder from them, and then dimension the cylinder.
Anyone know of an easier way to do this??? Anyway to do both ends within the cylinder?
Any direction or feedback is greatly appreciated.
