Hi All,
Quick question, I have a domed part that I need to know the highest point. Very critical, accuracy needed is around a .0001" max. My problem is there is a radius around the outside edge. I plan on doing a Cylinder around the outside and picking up a plane as close to the outside as I can, but I don't know if these points would be the lowest points or not. So can I do a scan and do a MIN of the point, zero on that point and then do a MAX of the points for the highest point? Does this sound like it would work? I haven't started the part yet; still have about an hour before I can start. Just trying to get my mind programmed first.
Thanks
Thanks
