I have generally stayed away from Clearance Planes and used my own move points. However, I am now dabbling in them and have a question about them. What is the point of the pass thru plane? So far it seems I would always want to set the pass through plane the same as the clearance plane that I want to use. In fact, I tried setting my clearance plane to X- and left the pass through alone (Z) and I crashed. The CMM did not clear the X- plane as I had intended. So I set both planes to the plane I want to clear. Is this designed so I can clear two planes? How does this work? The help file is of little help here.
Thanks,
Bill
Thanks,
Bill
